Results 1 to 4 of 4
Thread: Bypass volume pot?
    Aug 2009
    36
    Bypass volume pot?
    Hi,
    I have a keyboard with a bad volume pot that cuts out intermitenly. I am looking to jumper across it to bypass the bad pot from the circuit and could use a little technical assistance.
    The pot has 6 lugs and I want to know which ones to jumper. I have a multi meter and can run test if somebody could help me decipher the results.
    Thanks for the help,
    Mr.
    Jul 2006
    749
    Hi ManRay
    The brand and model of keyboard may help as some one may have a schematic and layout for it.
    However see the attached diagram and maybe can suss it out.
    With 6 terminals I expect it to be stereo with 2 identical channels.
    Two of the terminals should go to ground the only two connected together.
    From the diagram 1 and 1' .
    Two should be connected to the "other end" of the pots resistance and have the signal coming from the sound module.
    From the diagram 3 and 3' .
    Here from 1 to 3 and from 1' to 3' you should be able to measure the pot's or faders resistance.
    Turn the pot/fader to full volume and the wipers (the only 2 terminals left) should measure low resistance between 2 and 3 and 2' and 3'.
    A high resistance reading (twice the pots value)would indicate measuring between 3 and 3'.
    If you now bridge between 2 and 3 and 2' and 3' as long as you always leave the volume at full it should work.
    A new replacement fader would be better !
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,021
    Is it a rotary pot, or a slider?
    HAVe you resoldered the thing? Try that first.
    SLiders can be cleaned with sprays. You can also carefully disassemble it, wipe down teh resistive stripe, clean debris from the slider fingers, apply a thin film of Deoxit or MCL, and reassemble.
    Two gang rotaries are hard to do that to, but some will work.
    REad oc's discussion, but also, if the thing sorta works now, then turn the control all the way up and see which pins are shorted together.
    Dec 2009
    54
    It is tough to measure the value while it is still installed. The pot (pots) will have a three digit code for the value. 104 is 10,0000 ohms, 105is 100,000. Pots in general follow a fairly predictable progression for value 1, 2.5, 5. The center wire should be the wiper. You are thinking of lifting one wire and putting a fixed resistor between this and the wiper. if the other wiper has a wire attached then you need another resistor to complete the voltage divider for half volume use a 70/30 ratio for these adding up to the value of the pot. Most pots are 1 or two watts but seldom need to be. make sure your resistors don't get hot.
    I think I'd just clean or replace it.
  1. No Load Volume Pot; volume pedal
    By Guitarist in forum Music Electronics
    Last Post: 01-07-2010, 02:38 PM
  2. How to wire tone/volume pot bypass?
    By bhuether in forum Guitar Tech
    Last Post: 02-21-2009, 05:51 PM
  3. volume pot wiring
    By delb in forum Guitar Tech
    Last Post: 01-25-2009, 01:21 AM
  4. True bypass volume drop mod
    By stoneattic in forum Guitar Effects
    Last Post: 08-28-2008, 03:22 AM
  5. Volume pot trouble
    By dilly_Boy in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-17-2006, 07:22 AM
