Results 1 to 7 of 7
Thread: Help with transistor sub
    Nov 2007
    Murfreesboro,Tn outside Nashville
    79
    I have a Mashall VS100 with bad outputs. Can I use these as subs?
    BDV65 OEM
    can I use a 2N3055 or 2SD718
    the normal sub is TIP142
    BDV64 OEM
    can I use a MJ2955 or 2SB688
    the normal sub is TIP147
    using transistors I have if I can don't have the TIP's
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,025
    Basically no.
    First, the originals and those TIPs are Darlington transistors - internally they are dual transistors with a LOT more gain than plain old transistors. Like a gain of 1000 instead of a gain of 50.
    Second, the 2N3055 is not remotely shaped like the BDV part. The "package" is wrong. How would you mount it?
    Nov 2007
    79
    Thanks for the reply
    I didn't use my head on this one. I just had a box of new transistors and heatsinks for audio amps. I just didn't have the correct subs.
    I have the preamp working. The amp has been roughed up alot. It was threw out in the driveway at a Nashville studio. So it is just a project amp
    I will order the correct subs for the power amp.
    Thanks again for the info.
    Jess
    Old Timer Gtr_tech's Avatar
    Nov 2007
    Owosso, Mi
    1,537
    Every valvestate I've ever heard I wanted to throw out in the driveway......
    Nov 2007
    79
    I am sure you are right
    this one is a mess. I just pickup them up to mess with so I don't expect much out of this thing.
    18,025
    They make a lovely planter.
  7. #7
    Nov 2007
    79
    not this one not much left
    the cab is broken, and the panel with marshall logo on it is gone. I have it working as a preamp, just a few parts and it will have life again. I have a few more old amps to play with til parts come in.
    I just finished a Standell Studio 60 and a Custom head, Thanks for all your replys on this site. I am kind of slow to pick up stuff, but I have got alot out of you posts on all of these subjects.
    Jess
  1. Cathode Transistor?
    By lowell in forum Theory & Design
    Last Post: 05-16-2011, 06:20 AM
  2. Ampeg transistor?
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-20-2011, 02:15 PM
  3. Help identifying transistor
    By uvacom in forum Guitar Amps
    Last Post: 03-31-2010, 06:58 AM
  4. transistor madness
    By nopainkiller in forum Music Electronics
    Last Post: 11-18-2008, 07:09 PM
  5. transistor matching question
    By dusty tolex in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-27-2008, 09:10 PM
