Results 1 to 3 of 3
Thread: Tube table organized by type?
    Jan 2009
    Los Angeles
    294
    Is there a table or something that lists tube #s according to type? As near as I can tell there is not a direct systematic relationship between the type of valves within a tube and the tube designation #. I realize the correlation between the first # and the filament voltage, but beyond that things seem to be all over the map. Maybe there is a pattern and I haven't recognized it.
    Senior Member JHow's Avatar
    Oct 2009
    St Johns, FL
    481
    The US system is not rigorous, but the scheme is:
    First number indicating heater or filament voltage
    Next one or more letters indicating type
    Next a number indicating useful elements in tube
    Fourth, letter indicating size or construction type
    So like a 5Y3-G is:
    5 volts heater
    Y for rectifier
    3 useful elements
    G in a glass envelope
    Or 50L6-GT is
    50 volts heater
    L beam power amp
    6 useful elements
    GT - small glass envelope
    There are a lot of exeptions to these rules. Tube manual will help you out to specifically if you are looking for multi-purpose tubes like triode-pentode, triodr-triode, etc.
    Also, after I wrote the above, I found the following:
    Tube numbering
    Senior Member ThermionicScott's Avatar
    Dec 2009
    SW CR IA US NA PE
    463
    Go download this, and check out pages 71-74.
    - Scott
  1. Tube type question?? Vox
    By chuckedup in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-18-2010, 11:09 PM
  2. Space Charge Type Tube?
    By tbryanh in forum Theory & Design
    Last Post: 05-01-2009, 08:29 AM
  3. Type 4 vs. Type 9 Accutronics Reverb Tanks
    By tommy d in forum Vintage Amps
    Last Post: 03-16-2009, 03:14 AM
  4. Replies: 2
    Last Post: 03-28-2008, 09:31 PM
  5. Replies: 14
    Last Post: 02-10-2008, 01:20 AM
