Results 1 to 5 of 5
Thread: Ye Olde Korg Chromatic Tuner WT-10A
    Jul 2006
    749
    korg chromatic tuner WT-10A service manual
    I know this is just about the first thing Korg ever made.
    Keio Electronic Lab,Corp Tokyo Japan
    This one is in perfect nick even the vinyl pouch - unfortunately it got dropped
    recently by an over enthusiastic user and would like to get it going again for the owner.
    The oscillator/tone functions ok but no meter reading.
    Cannot see a crystal although there is a black sealed component which I suspect is some kind of resonance device...
    I guess as the tone function works the osc circuit is working.
    Suspecting the meter itself so even the specs of the meter may help.
    Thanks
    Jul 2006
    425
    Korg WT10 Guitar Tuner
    Attached Files Attached Files
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,036
    Before spending time on it, do check the meter. Meters are meters, so it should be easy to see if it deflects or not with a small current applied. The meter movement by far is the most fragile part of it.
    160uA movement? There is one I don;t see in catalogs.
    Dec 2011
    1
    Quote Originally Posted by vintagekiki View Post
    Awesome!
    Hey, what are the chances you've got the original users manual someplace? I just inherited one of these bad boys and I'd like to learn its quirks before I play with it.
    18,036
    Don't have, what do you need to know? Tuners are all kinda the same. SOme make tones to tune against, some don;t. There'd be a SOUND selection somewhere on it. WHatever note you want to tune, you select with the knob or on newer units by stepping. Many have an internal microphone, so you can just sit it there. If you plug a guitar into the input jack, it turns off the mic part. SOme have an output jack so you can just leave the tuner in between the guitar and amp. SOme will have a note adjustment so you can set the reference pitch. SImpler units will just have A = 440Hz, but fancier ones will allow you to set the A to a range. SOme guys tune down to A=400 or something to accomodate the singer or to allow the guitars to tune down some for string action.
  1. Schematic needed for Korg DTR-1000 Tuner
    By W3KQ in forum Music Electronics
    Last Post: 01-22-2013, 07:34 PM
  2. Replies: 9
    Last Post: 04-16-2012, 10:21 AM
  3. eden wt 400
    By blaise in forum Guitar Amps
    Last Post: 10-20-2009, 07:24 PM
  4. Eden WT-300
    By clintronics in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-28-2009, 07:40 PM
  5. HA3500 blowin' ye ol' fuse
    By lowell in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-16-2008, 10:27 AM
