| | #1 |
| Junior Member Join Date: Feb 2007
| Using hifi-amp
Hi, this is my first thread in ampage. I have an stereo tube amp, which was removed from an old reel deck. It uses an 12AX7 and two EL84s. I would like to make this use of guitar practice amp with my digitech rp80. 1. However, I heard that tube amp can be broken without connecting speaker. To keep it from being broken, should I pull out one of EL84s? 2. I don't have any extra spearker, so I think I should pull out tube of one channel. However, I heard that to pull out tube(s) can cause to increase B+ overall and kill all parts (soon or later). Is it right? To make story short, should I modify its PSU in order to lower the B+? Thanks. use RP80, However, it has only one channel. I would like to put my digitech digital gear (RP80) into it. |
| | #2 |
| Member Join Date: Nov 2006 Location: Sacramento, CA
I don't understand what you are using this for if it's not connected to a speaker, however I believe you are right about needing a speaker and raising the B+ voltage. Whether or not this will damage the rest of the amp is hard to say, it may , or your amp may be able to handle the increased voltages.
| | #3 |
| Member Join Date: Jul 2006 Location: canada ontario
Pull the tube, measure the B+ Tubes can take a fair amount of voltage. Those tubes, in class A, are only a few watts |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
