Go Back   Music Electronics Forum > Amplification > Tubes (Valves)
Old 02-09-2007, 09:33 AM   #1
High gain pre-amp tube / valve - Question
I'm wondering...
If I use a tube that is rated high gain or tested for high gain as the pre-amp gain tube (V1) will the amp:
a) have more distortion, smoother sustain?
OR
b) distort later when I turn up the gain control? That is, will the tube handle higher gain WITHOUT distorting?
To a more specific question:
If I can choose between "JJ /Tesla ECC-83-S" (JJ's regular 12AX7) and "JJ / Tesla ECC-803-S", described as a "High-gain 12AX7" to use as the pre-amp gain tube (V1) in a JCM800 2204 50W amp, which would give me a warmer, fatter, "endless sustain" type sound?
Thanks!
skeitaridaudans is offline   Reply With Quote
Old 02-09-2007, 10:15 AM   #2
Supporting Member
Steve Conner's Avatar
The answer is that a higher gain tube will give more distortion and more sustain, but not necessarily any of those other buzzwords like "warmer, fatter, smoother". You could maybe even replace the first two tubes with those high-gain types for an even bigger effect.
Steve Conner is offline   Reply With Quote
Old 01-19-2008, 11:59 PM   #3
Red face Awful
It might even sound awful,or buzzy,or spikey.
Swappin' tubes is a blast !
JJ
Jammin'John is offline   Reply With Quote
Old 01-20-2008, 06:39 AM   #4
Iv ordered an entire tube set with high gain testing for all except the PI tube. In all honesty, I didnt notice realy any diffrence. I wouldnt pay the extra cash to get them tested. But....thats just my opinion.
Brad166 is offline   Reply With Quote
tube question foe a 5e7 john t Tweed Builders 1 03-09-2007 10:24 PM
how much gain can you get from an epiphone valve junior? gtrboy Guitar Amps 2 12-12-2006 10:53 PM
High Gain Phase Inverter - MOSFET Follies 8-) R.G. Theory & Design 10 12-01-2006 10:10 AM
Too high plate voltage on preamp tube slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 22 10-15-2006 08:51 PM
Question about el 84 tube amp............ jstich Other Amps 18 07-22-2006 11:55 AM
