Results 1 to 6 of 6
Thread: To add a standby switch or not?
    daz
    daz is offline
    Jan 2007
    1,534
    Classic 30, 4 el84's at 30 watts. Modded to cathode biased. I use it for just a few minutes here and there usually 3-5 times a day for an average of 5-10 minutes.
    Seems like that would wear the tubes pretty quick, or is there a reason it doesn't need one? If it does, anyone know a schematic i could copy the switch from or are they all pretty much the same?
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,242
    If you want one, just break the B+ somewhere. A real easy spot is the two red wires from the transformer. Insert a switch there and it turns the B+ off and on. DOn't even have to pull the boards.
    But really, why bother? Back when everything was tubes, table radios and TVs didn't have standby switches. Nor did the Hifi in the rec room. On somethng that small, I don't think cathode stripping is an actual issue.
    daz
    daz is offline
    Jan 2007
    1,534
    I just wasn't sure, but if you think it's not a problem i won't bother. I just figured that being turned on and off so many times it might be a problem. Guess i'll just get a new set of 84's and swap them out to see if they sound the same of not, then put the old ones back in if they sound the same. Thanks Enzo.
    Senior Member mac1amps's Avatar
    Sep 2006
    Chicago
    172
    I'm not one to want to start arguments, but I'd have to say that adding a stand-by switch to a [Peavey] Classic 30, IMO is an excellent idea (as I have done it to many of them). PERHAPS not so much for the cathode stripping factor as for the purpose of maintaining the tubes (and amp) at a "warmed-up" state for when you are say, going on break (or something similar), and will be playing again, but still want to give the amp/tubes a chance to partially cool, especially since EL84's give off alot of heat for their size, even when you're not playing. As far as installing it goes, I hope you're somewhat experienced with dissassembly/re-assembly, working with P.C. boards, etc. for as much as I like the Classic 30's, they are a bit tedious to work with, especially if you aren't familiar with them.
    daz
    daz is offline
    Jan 2007
    1,534
    I only play out 2-3 times a year anymore so thats really not a concern. Cathode stripping was my only concern due to my turning it on for a few minutes at a time at home 4 or 5 times a day. As for disassembly, i've modded it and had the boards out many times so yeah, i'm very familiar with what a PITA it is. (especially when it comes to those board jumpers breaking !)
    Quote Originally Posted by mac1amps View Post
    18,242
    It is only an argument when we get angry over it. Discussion of alternative viewpoints is welcome.
  1. Standby switch question
    By Matt T. in forum Theory & Design
    Last Post: 02-08-2007, 08:11 PM
  2. B+ variating in standby???
    By Satamax in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-03-2007, 09:37 PM
  3. Noise when standby on or powered off
    By Thorny in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2006, 05:52 AM
  4. 5E3 Standby and Ground Wiring
    By wagabone in forum 5 E 3
    Last Post: 07-11-2006, 09:36 PM
  5. Standby allowing sound through...
    By Riscchip in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-02-2006, 07:39 PM
