Results 1 to 6 of 6
Thread: Failed Deluxe Reverb
    BDM
    BDM is offline
    Feb 2007
    13
    I'm new to amp repair. My Deluxe Reverb started making loud burping noises several times a second which I was able to halt by turning down all levels. Trying to bring up one channel slowly reveals very weak power. The silverface amp seems to have all original components except for some tube changes. As I look towards overhaul, can I test voltages with the speaker unplugged or must it be plugged in whenever power is applied?
    Any advice on Kendrick's $70 DVD on repairing Fender amps?
    Senior Member Satamax's Avatar
    Jun 2006
    Southern french alps, right by the Italian border
    781
    NYC
    1,478
    It is best to keep something plugged into the speaker out,either the spkr or a dummy load.It sounds like you have a low frequency oscillation and turning the amp on with no load would be the same as putting a signal thru it with no load,no good for your OT.The link Max gave you is exactly what I would check first,it is not uncommon for caps in an amp this age to need to be changed,just normal maintenance.I am not familiar with the Kendrick Video you mention but have his books,and have spoken to him many times and he is very informative and knowledgeable.As for your problem I think Max hit the nail on the head,time for a re-cap.
    Jun 2006
    781
    Talking
    Thankfully i hit the nail on the head , otherwise my fingers don't like it! I have broken bones in my hands due to hammer blows
    BDM
    BDM is offline
    Feb 2007
    13
    7025 --> 12ax7
    Okay, thanks. I placed an order with Mouser for all new electrolytics.
    Also, I had two bad 7025 tubes. I have some spare 12AX7s. They're an okay substitute, right?
    Jun 2006
    781
    They should be!
  1. Deluxe Reverb LDR
    By weeping6 in forum Build Your Amp
    Last Post: 10-24-2007, 01:07 AM
  2. BF Deluxe Reverb, reverb tank
    Last Post: 02-25-2007, 05:27 PM
  3. '79 Fender Deluxe Reverb
    By garcia in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-11-2006, 04:59 PM
  4. Blackface Deluxe Reverb Tank?
    By Watto in forum Vintage Amps
    Last Post: 10-29-2006, 03:21 PM
  5. Deluxe Reverb RI help
    By lrs11 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-13-2006, 12:17 AM
