Results 1 to 5 of 5
Thread: What model Masco is this?
    Apr 2010
    Los Angeles
    88
    Does anybody know what model Masco amp this is (and where I can get the schematic)? The tube lineup is 6SJ7, 6SC7, 2x6V6 and 5Y3; the chassis has a vibrator on it, so it's an AC/DC model. Also, the back doesn't have the customary terminal strip with the impedances printed on it; how do I determine the correct impedance for the speaker(s) that I connect to it?mystery-masco-back.jpgmystery-masco-front.jpg
    Senior Member JHow's Avatar
    Oct 2009
    St Johns, FL
    483
    I can't help you with the model or schemo, but with regard to the OT and impedance question, the link below discusses this dilemma, how to figure out an unkown transformer. Basically, figure out turns ratio, calculate relfected impedance, make deductions about what your output tubes want to see and what imp. load your speaker(s) will create.
    Output Transformer Impedance
    also, geofex.com has info on transformer "reverse engineering" and testing.
    Jun 2006
    3,313
    Bear in mind that Masco often ran lower primary Z on 6V6 tubes than is typical, 4.5K is listed for some of their 6V6 amps.
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    2,911
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Apr 2010
    Los Angeles
    88
    Thanks
    Thanks JHow and MWJB for your information on transformers; after all, that was the most important question. And Bruce - at first I thought it was an ME-18p, too; that's the reason I bought it. I asked the seller what tubes were in it, and only the preamp tubes had markings on them (and they were the same as in an ME-18p). Once I got it, though, I could see a faint 6V6 on the chassis in front of one of the power tubes, and as you know, an ME-18p has 6L6s. I liked the pretty pictures, though; that ME-18p looks to be in almost mint condition!
  1. Masco Amp Question
    By JHow in forum Harp Amps
    Last Post: 06-25-2010, 07:54 AM
  2. Masco MA17N
    By madkatb in forum Harp Amps
    Last Post: 04-09-2010, 10:46 PM
  3. Masco MAP-120N
    By baddog in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-04-2008, 05:47 PM
  4. Masco MA-8
    By hearforever in forum Conversion Projects
    Last Post: 02-20-2008, 12:15 PM
  5. Masco MA-8 for guitar
    Last Post: 01-12-2008, 05:20 PM
