Looking at the thread title I wanted to write 'Maybe it doesn't know the words'...Yuk yuk
Considering it's age it might be a good idea to re-cap the power supplies and any other electrolytic caps.
Chuck
I am trying to find the source of hum in my RG80. I got this amp recently, so I don't know any history, that is I don't know what it sounded like when it played right. I wrote elsewhere about cleaning it and finding the lone chip that runs the reverb reversed in its socket. It works, from the standpoint of both channels amplify, the power amp works, it is loud, the footswitch switches channels, all the controls do their proper function, except maybe the presence, which to me is hard to discern, the reverb verbs. It still needs some more work, which I am doing in my spare time. There are two annoying "features" at the moment: hum, and hiss when you turn the reverb up to 10. The next thing I would like to fix is the constant hum which is there when I power up, regardless of whether guitar is plugged in and it is totally unaffected by the gain or master volumes for either channel, from which I assume the hum is entering in the power section. I was worried about DC on the speaker, but measuring from spkr out to ground, I get .003VDC. That doesn't seem like a lot, but maybe I'm wrong? WHat else can I tell you of importance? I am open for suggestions. I attached the schematic.
Chuck
I can do that. They are probably all original - mostly all the same brand (color). Given the amount of dirt that was on this thing, I think it sat in a garage for a long long time. It has an inspection sticker on the side of the chassis that is dated 1983, which I am assuming is its birth year.
Well. I did replace the e-caps last nite. There were a lot of 10uF-50V and some odd 4.7, 3.3, etc. The big filters ended up with higher value 6800uF-63V. Changing caps has improved but not eliminated the hum. I looked over the board for any dodgy solder joints or cracks in traces. I re-flowed a couple of spots - but no change.
If you turn down all of the controls how much hum do you hear? Does the reverb control still make the hum louder?
Try and isolate the source of the hum by using the controls and the foot switch. The signal actually travels out to the foot switch in the cable. Do you have one plugged in?
If the reverb circuit adds hum try and move the output side of the tank away from the power transformer.
Have you checked all of the grounds for good connections? What about any shielded wires, does moving them around increase or decrease the hum?
Worst case, you could try and ground the signal path at various points to see where the hum starts.
Thanks for the advice. I will try to answer in order.
With all controls on zero, I hear the hum, it is low frequency, power line hum. It is there with the guitar plugged in and guitar out.
If I remove guitar and turn up master volume and gain on either channel I get additional hiss and buzz and the original hum is underneath.
If I insert guitar, but do not play a chord, turn up gain full and start to turn up master, I get horrible feedback howl, which I can't take past about 5 on the dial. Actually, standing in front of this it is loud at 5, so I have not tried this thing all the way up yet.
The reverb control adds it's own noise (buzz) on top of the original hum. As you dial up the reverb, it increases in noise. You can play over it, but it is there.
I do have the foot switch. I tried turning down all controls to zero, removing the footswtich, but still get the hum. The footswitch makes some noise like a loose connection when inserted. You have to jiggle it a bit to get it to light the channel diodes, but once you do that, it has the proper functions: it has one switch for jumping between channels, and the other switch will allow you to blend the two channels. The green and red diodes light up on the panel and the footswitch for the appropriate channel.
With the footswitch in place, I still have the original hum. I tried moving the switch around the room, it has a long cable. I also tried turning off the lights (flourescent), and tried another outlet in the garage, but neither of those things made a discernable difference.
My feeling playing the controls is that this hum is getting in after the master volumes, because they don't really affect the hum. Fully cranked, they add their own noise, but on top of the base hum.
The reverb circuit adds more of a hiss, than a hum. The output side of the tank is on the other side from the transformer, also this is a combo and the tank is down at the bottom of the cabinet and the chassis is at the top, so it's probably more than one foot away. I took the tank out and put it on the bench and tried different locations relative to the chassis, but it didn't affect hum. It does seem that one of the male rca connectors is loose, however. I tweaked it with pliers.
I checked the two input jacks, there are two ground from the board that terminate on the #1 jack ground, I re-soldered at both jack and board. There is one board ground that also grounds the reverb in and output line shields, it is held with screw, I tightened that one. The main filter ground is tight, as is the centertap for the transformer and the ground for the .005 cap from the neutral line. I tested speaker outs for continuity. There are of course a lot of other places that touch the chassis, so this task will probably take a bit more effort.
The only shielded wires are the runs to the reverb tank and two wires that run from the panel diodes to the footswitch socket. Moving these later does tended to increase hum.
Not sure what you meant here. I tried to ground out the effects return, but it hummed worse than without. Measuring some oft he voltage listed on the schematic, I got it to quiet down some of the hum when I touched the probe to Q8/9 emitters, and also to the r45 base. Makes me think something is amiss in the power section.
Just to be sure that I understand this correctly, you replaced all of the e-caps in the amp?
I usually recommend grounding out the signal path with a capacitor. If you're not careful you can ground out dc supply voltages by mistake.
Are there any signs of previous work done on the power amp section? How do the voltages in the power amp compare to the schematic?
Is the howl you describe actual feedback from the guitar or is it amp oscillation controlled by the volume control?
52 Bill: Thanks for helping!
Yes. I replaced all the e-caps throughout the circuit board and also the two large power supply ones. It did seem to improve the noise, but did not eliminate the hum. They match the schematic in terms of values and location in the circuit. There was one 10uF-50V jumpered from the main power filter ground to the ground for the reverb output shield ground. That isnt in the schematic, so I didnt replace it. I did jump a cap across that to see if it made any difference to hum, but it didn't - not sure what that cap was supposed to acheive. Also it was different color than all the others, so I figure it was later addition.
Got it. Will try to avoid that.
Well, the four 2N6254 all look original, all the same RCA. The TIP31C and TIP32Cs don't match, the 32cs are Texas inst, but the 31C is some other brand (HSC?). The resistors are a mixture, the 100 ohms are carbon comp, others are film, but they don't all match in terms of color. Among the high-power resistors (.6, .27 ohm), those all look orginal unmolested.
As to voltages, I attached a table.
I think it is oscillation, you can turn down the control and quell it. It starts quiet and builds up to a howl. The guitar was actually in its hanger on the wall , just plugged in, didn't hit the strings at all.
Well, I finally got some more time to look at this, but am still stumped. My voltages don't look too far off from the schematic. I'm not sure of the level of precision I should expect, though.
regarding 52Bill's suggestion about grounding out the signal path with a cap, I would like to try this, but I am not sure I am getting the test right. If I understood correctly, you are suggesting I shunt the signal path with a cap at various points to see if the hum is being introduced before that section (i.e., hum will go away if the shunt is introduced afterwards)? I am finding that the shunts seem to introduce more hum of their own. I feel like there is something simple that I am missing here.
Isolate the problem. And one problem at a time.
Plug the guitar into the FX return jack and turn the guitar volume control to zero. Does the hum remain? If so, that means the power amp is hummy, if the hum goes away then the preamp has the hum. That will be the same as shunting to ground the signal path, at least at that location. You could indeed just ground out the tip of the FX return jack. No cap needed.
And you can connect the FX send to some other amp to listen for hum on the preamp signal.
A scope is the best tool, but to look for power supply ripple we can also use your meter set for AC volts. Your powr amp runs on +/-40vDC, filtered by those 6000uf caps. There will probably be a little ripple on each. But the other power supplies should be clean and free of ripple. There is a pair of zener derived 12v rails for the IC. Are BOTH at the same voltage, hopefully close to 12v? And free of ripple?
Pull the reverb IC. ANy effect on hum?
There is a +24v rail for the preamp, also zener derived. Is that clean and ripple free?
Thank you for responding to my post. I feel this should be an easy deal, but not so far. I have tried to follow your tips in order.
Yes, and it gets louder.
So, this would indicate power amp.
I tried grounding the tip of the fx jack by inserting guitar cord into fx return and touching tip to ground. inserting cord increased hum, until I touched the tip, then it went back to what I would call the 'baseline hum'. So no change in hum by grounding fx return jack tip.
I did this experiment for both green and red channel. It was hum-free for both. I used a head that is quiet and I used the speaker from the randall. Safe to conclude this is power amp issue?
Here I have some issue with my meter or my understanding of how it works: it doesn't read AC ripple on the power supply, it seems confused. The meter readings fluctuate all over (goes high, goes low, zero) at the -40/+40V, -12/+12, and 24V nodes. It will read the line voltage at 121VAC, however. It does read DC okay: +41.2, -41.1, -12.13, +12.05, 25vdc
I do have an old scope, which, if my scoping is correct, gave me the following: on the +40V node I get a distinct sawtooth wave with amplitude about .08V. (volts at .1V/cm, time at 2ms/cm). I have posted a shot of the scope.
The 12V and 24V nodes are substantially less than .01V ripple using .01v/cm scale.
I get - 12.13 VDC and + 12.05VDC.
No change on the hum.
I get 25VDC.
Then I start to wonder if the thing was designed to be any less noisy than this. There may be shared copper in powr supply returns.
I am wondering too. The hum is not really noticeable when you are playing, but if you stuck a mic on this and recorded, you would pick it up, I believe.
What did you mean by "shared copper" in power supply returns? That the grounding system is introducing the hum somewhere? I have to say, from a layout perspective, all the lines to the output transistors, the send/return jacks, the output jacks, etc. are all bundled and stuffed along the back wall of the chassis and tightly bound with cable-ties. On the board itself, the ground connections seem to be mostly achieved through the metal standoffs and screws that hold the board down.
Shared copper? A shared current path.
I have no idea how this is laid out, but making up an example:
The input to the power amp has a resistor to ground 47k R40. Now imagine that resistor is grounded to the same point that C38,39 are gounded to. And from there a wire over to the CT of the PT. That would mean the ground retirn path of the main filters, and their ripple currents was through the same path as the ground return for the power amp input. Whatever that ripple current was over the resistance of that ground path would cause a voltage drop across that resistance. That resulting ripple "signal" would be impressed upon the input signal to the power amp.
This has nothing to do with radiated noise, so bundling and tie wrapping wires has no effect on this.
I don't think we asked yet, is your hum 60Hz or 120Hz? (Or 50Hz/100Hz in other parts of the world) 120Hz is power supply ripple, the 60Hz is grounding, shielding, radiated, etc.
Enzo:
Thanks for your reply so many months ago. I am picking this project up again, after a long period of focusing on my work (what a concept!) rather than hobby. I think hum is 60hz, but I will check again and verify.
JHow
I finally got to look at this again this weekend. Status is unchanged. It is 60hz hum, not the 120 hz buzz. All the electrolytics were replaced in August. I double-checked the polarity of each this weekend, just to rule out a backwards-installed cap. The filters c38 and c39 are grounded to their own lug on the chassis. Nothing else is grounded to that same point. The pcb is grounded at several spots (six screws that look like they ground to frame and a line to the input jack and a line to the reverb footswitch jack). Maybe I am being picky, because the hum is not really noticeable if I am standing and the amp is on the ground, but I can hear it if I put my head down next to the speaker. But I feel like I have tube amps that I built myself that are quieter - so I would like to get rid of it. Any thoughts anyone would have would be appreciated.
Sorry I can't help much about further reducing the hum, but just to let you know my '86 RG100ES also has a hum. I'm thinking it's normal for these amps.
Thanks for the reply. I think you might be right. I really don't hear it if the amp is on the floor and I am standing up. I just have quieter amps, that's all. When you crank the amp, it doesn't matter!![]()
Yup... Probably just the nature of the beast due to the ground scheme. Not much you can do on a PCB. You could try isolating some things and dick around with it, but the returns may be minimal. I know that once I'm into a problem it becomes easy to hear it even when it's almost not there. Sometimes you just have to look things over and have the confidence to know you've done your best short of re-engineering the amp.
"I should have been born sooner. Of course, if I had been, I might be dead now." trem
Stop me if I'm being obsessive but in regard to 52 Bill's question "Have you checked all of the grounds for good connections?" I would remove the jacks and clean the chassis with emery paper and refit with a star washer with a dash of deoxit etc and make sure all the other grounds are likewise.
Looking at the scope picture it seems like inadequate filtering how far are points
A on the diagram and B apart I mean where the positive leaves the 6000uF capacitor and goes to the collectors of the amp ...I'm suggesting at that point
A & B on the Amp output portion of the diagram try tacking say 2200uf to ground there and see if it makes any difference.
There is a possibility the new replacements are maybe duds ..does happen some times.
Well, oc disorder, it's worth a shot. I tightened the jacks but didn't emery the contact surfaces. It would be easy to try your idea on the caps, too. I'll play with it some more and let y'all know if I get things better.
Sorry to resurrect a thread that is long past... However, I have this same amp assembly date 1986 and it behaves in the same exact way as mentioned throughout this thread. Actually, the hum is not that noticeable in most locations in my house except for one room where it just goes ballistic! Probably a bad grounded jack in that one room. Had a jazz band guitarist use it in my living room and it was fine. In my bench room it works the same but in this other room where the ground is not as good the hum is insane!! Took it over to my brothers house for a jam and man oh man the hum was horrible. Brought it home that night and the hum in my bench room was much better. The bass amp that was in my brothers house had a hum too, but my hum on the Randall was just god awful!
The guy I bought it from said the hum got worse over time...??? I am about to recap the sucker and do all the stuff that can reduce some stray capacitance etc. However, something just occurred to me about the power transformer on this amp. It has those shoelace type wires instead of insulated rubber wiring. My gut is just telling me, that like Enzo said, it has a shared ground copper winding to return path of the PT. That I think is what is going on with this amp. However, tonight I just thought that the wiring is like shoestring material. Just like you find in an old style vintage single coil pickup from a Telecaster. My thought is now to insulate those wires before doing any cap job. Isolate the problem right?
My question(s) here is... Do you think this might be the reason the power supply is adding hum to the amp by way of shoestring wires? Do you think insulating these wires might help reduce some hum? If I do this what would you recommend to wind around the wire to add some insulation to these suspect wires from the PT?
Thanks in advance as always you guys give such great responses. Even when I have a silly thought like tonight or most nights lol.
Edit: Just wanted to say one more thing... I just recently acquired a Randall RG30 and it is from 1981 with all original components. This amp is now my studio amp!!! Totally silent no hum! It's a great amp man. Not sure that is even related but just ironic in a way.
Double Edit: All of the wires form the PT are shoestring insulated wiring...
Last edited by DrGonz78; 05-20-2012 at 12:53 PM. Reason: Just wanted to say one more thing...
I don't know if this is helpful, but I used to have an 80's era RG-80 combo. While I don't remember it specifically humming, I do remember that it was not a particularly quiet amp. Might have been hiss+hum, but mostly hiss? That's the way I remember it...
LL
If you turn the reverb all the way up to 10 you can here a hiss... However, this is a 60hrtz ground hum and occurs w/ all knobs turned to zero w/ no guitar plugged in. The two black wires from the on/off switch that lead to the power transformer are of the shoestring rag wire types. Also, these wires pass right over the filter caps and not sure if that has any effect to increase a hum? Then the two primary and center tap wiring is all the same rag wire type insulation. So, just got me thinking that the PT's on these amps have these wires and might create an increase in hum.
Edit: Have read about rag wire losing it's ability to fully insulate wires over time. So, in this case I just assume this could be why the previous owner said the hum got worse over time.
Sorry I didn't re-read thoroughly... So stop me if I'm being redundant.
Any high current power lines around sensitive leads can induce hum. If it's 60Hz it's mains AC. If it's 120Hz it's HV ripple. But even if it's not ripple that doesn't mean the filters aren't old, and perhaps have high ESR. High ESR means the leads on the filters carry more signal sensitivity. So I think it could be possible to induce 60Hz hum on them. I know that replacing the filters in old JC's can cure hum. If the electros are old I don't see a down side to replacing them. If it fixes the hum you're done.
DrGonz: I think you are getting insulation mixed up with shielding. Plastic, cloth, or rubber insulated wires are all unshielded. The insulation is for safety reasons, not noise.
"So, for my small experience in the trade I would think that killing customers is, at the very least, bad for business." -Chuck H
Disclaimer: "Take my advice; don't listen to me"-Neil Young. "I'll lie again and again and I'll keep lying; I promise"-Henry Rollins.
As OP here, I still have my RG and it still hums, but only if you really stick your head down and listen to it. Standing up, five feet away you really don't notice it. Use the red channel and I stopped worrying about it. Oh, mine also hisses a bit when you turn up the reverb.
I will be interested to know if you find a fix, however.
Bill, well it sounds like an odd question and was figuring it was worth asking to see if it makes any sense to anyone here... Since you all have much more experience than I do. But yeah it seems like it might be just time to get on with filter recapping.So you're thinking that cloth covered transformer wires can leak 60 hz hum into the power supply filter caps?
Please explain.
Chuck, my main thought is that some of the wax or plastic insulation could become brittle or cracked underneath some of the rag wires from the PT. So high ESR from the filters could theoretically make it possible to induce a hum. I was thinking if any of the PT wires were brittle and not fully insulated anymore that could be a cause to induce hum over such components(filter caps)? I read about how the wax or coating under the cloth rag wire can dry out and crack a bit...Any high current power lines around sensitive leads can induce hum. If it's 60Hz it's mains AC. If it's 120Hz it's HV ripple. But even if it's not ripple that doesn't mean the filters aren't old, and perhaps have high ESR. High ESR means the leads on the filters carry more signal sensitivity. So I think it could be possible to induce 60Hz hum on them. I know that replacing the filters in old JC's can cure hum. If the electros are old I don't see a down side to replacing them. If it fixes the hum you're done.
Yeah G-One point taken here... I was only really referencing the shoe laced pickup wiring as a way to describe what this type of wiring looks like to me. Later I found out it is called rag wire. But yeah I was just a bit confused to how to describe this type of wiring. Yeah I understand that they are different sorry my writing made it a bit confusing.DrGonz: I think you are getting insulation mixed up with shielding. Plastic, cloth, or rubber insulated wires are all unshielded. The insulation is for safety reasons, not noise.
JHOW, did you ever plug it in somewhere and had a huge hum??? I described that when I bring it to a few other locations it hums like 60 monks going at once. Yeah in my work shop it really is not humming all that much... Identical to how you describe your amp(only when you put your ear low towards the speaker). I might add some tubing on the wires that are from the PT that cross directly over one of the filter caps. Also, I will do a recap job. Then I will take it in the horribly grounded room to see if it is responding the same way. The thing that perplexes me is that I played this amp at my brothers house with a band recently. Both bass amp and guitar amps were humming as the ground in the house was not the greatest. Came back 2 weeks later w/ a little Marshall 15 watt amp and barely a hum on the same outlet. That just confuses me but will change caps and test to see if the caps are indeed the major culprit to that type of huge hum change. The amp sounds great in the few rooms that I can depend on good grounds.Standing up, five feet away you really don't notice it. Use the red channel and I stopped worrying about it. Oh, mine also hisses a bit when you turn up the reverb.
Thanks for all the great feed back. Now most will respond bad grounded jack can't be an amps fault. You are right, but this one has a coupling effect that makes it hum louder than any other amp in the same room. So, my goal here is to at least get the hum to be bearable in these rooms where the amps hums a little more. I would love to have every place just be grounded better but if I sell this amp I don't want some guy taking it somewhere and having this anomaly.
