Results 1 to 6 of 6
Thread: Scared to plug in motor
    Jun 2007
    Chicago
    2,198
    Blog Entries
    1
    Hey all,
    I'm sorry this has nothing to do w/ amps. I have a Delta thickness sander that was caught in a basement flood. The motor got quite wet. I pulled it apart and dried the internal caps etc.. and have let the thing dry for a couple weeks. I have plugged it into my bulb limiter and don't think that that is a good test for this motor as I believe it draws WAY more current than a typical guitar amp. (the bulb glowed brightly)
    The motor is 1 1/2 horse power, 12.8amps, 3450 rpm at 115v, Insul Class B3, Thermally protected. Does anyone know if I can safely plug this thing in to test it out?
    rf7
    rf7 is offline
    Supporting Member rf7's Avatar
    Sep 2007
    458
    I'd bring it up on a Variac, with an ammeter in line to see how much current it's drawing. My Fluke meter only goes up to 10 Amps though, so you might need a Heavy duty Ammeter to check the current.
    Supporting Member
    Nov 2008
    los angeles
    124
    You might try a GFCI outlet as an initial test.
    Feb 2010
    328
    Does the motor turn freely by hand? As long as the bearings haven't rusted any, I would not hesitate to turn it on, since you've already dried it out. I've seen motors at work --even open-frame motors--run under some appalling conditions.
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,263
    More Googleing should turn up more specifics. If it spins free, I'd just plug it into a properly protected outlet (fuse, breaker, GFIC) and have a fire extinguisher near by. Because of the high inrush current nature of starting a motor, I don't think our typical "controlled start" methods are going to work. And your light bulb (assuming it was 100w) was seriously undersized. Your motor pulls about 1500 watts.
    http://www.nema.org/prod/be/enclosur...lect_equip.pdf
    Motors which have been flooded by water may be subjected to damage by debris or pollutants.
    This may result in damage to insulation, switches, contacts of switches, capacitors and overload
    protectors, corrosion of metallic parts, and contamination of the lubricating means and should be
    evaluated by qualified personnel.
    The manufacturer should be contacted for specific instructions on possible disassembly, cleaning,
    and drying of the motor housing and internal components by trained personnel. Also, a method
    for drying is described in ANSI/IEEE 43-2000, A2 and A3.
    -Mike
    Humor is the best alternative to serial killing. - Chuck H
    Jun 2007
    Chicago
    2,198
    Blog Entries
    1
    Well we brought it up on a Variac and all is good! Thanks guys.
  1. Schatten winder motor
    By achase4u in forum Pickup Makers
    Last Post: 01-04-2011, 04:32 AM
  2. AC motor controller
    By jjj in forum Music Electronics
    Last Post: 09-29-2009, 10:03 AM
  3. stepper motor traverse
    By David King in forum Tools and Coil Winding Gear
    Last Post: 12-23-2008, 07:49 PM
  4. got a motor need help
    By hgguitarguy in forum Pickup Makers
    Last Post: 12-06-2008, 01:23 AM
  5. Adding a grounded plug, need help
    By Warped in forum Other Amps
    Last Post: 03-30-2008, 03:31 AM
