| | #1 |
| Junior Member Join Date: Feb 2007
| reverb tank change
hi everyone. i have a brand new vox ac-15 reissue and the reverb tank sounds pretty bad. from what i've read online i've determined that there is nothing defective with my amp--the ac-15's just have a cheap tank in them. so i want to put the tank from a silver twin i have, a 73 i believe. what do i need to do to make sure that the electrical requirements, etc. are being met?
| | #2 |
| Lifetime Member Join Date: May 2006 Location: Wise, Virginia
Check out this link: http://members.tripod.com/~roymal/accutron.htm You want to make sure that the tnak will physically fit, that the input impedance matches and that the output impedance matches - I doubt that you have a tank that uses a lock or is mounted in a funny orientation. Your Fender tank should be a 4AB3C1B so if you've got the same designation on the Vox tank you're removing then they should swap fine. Rob |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| BF Deluxe Reverb, reverb tank | weeping6 | Build Your Amp | 6 | 02-25-2007 05:27 PM |
| Why did Fender change the cathode cap... | AdmiralB | Vintage Amps | 3 | 11-25-2006 12:09 AM |
| Blackface Deluxe Reverb Tank? | Watto | Vintage Amps | 7 | 10-29-2006 03:21 PM |
| installing a reverb tank | MitchK | Mods & Tweeks | 3 | 10-09-2006 06:43 AM |
| Change polarity | Magnetosaure | Pickup Makers | 1 | 08-24-2006 01:10 AM |
