| | #1 |
| Junior Member Join Date: Feb 2007
| Ampeg BA-115 Bass amp
Hello I have ampeg ba-115 bass amp that has blown the drivers and outputs and a resistor at r31, I dont have a schematic but looks like one output is irfp9440 and the other is irfp140 with drivers Je350 and je340 dont have any idea on the resistor as its destroyed if these part #'s are correct any suggestion as to where to get them or if there is a sub for these. Thanks in advance......Cal
| | #2 |
IRFP140R and IRFP9140R. The drivers are MJE340 and MJE350 R31 is 220 ohm as are the other three resistors in series with the drivers. The FET gate resistors are 47 ohm. If the FETs burnt, then the gate resistors are suspect. Change them no matter what. These parts are generic. The little MJE340,350 are stock Moto (now ON Semi) And if the exact IRFP numbers are not in stock at Mouser, something reasonable could be subbed. Mouser will even usually cross them automatically. DO NOT USE the NTE stuff. Get real parts. ANd you can send me an email with Ampeg BA-115a schematic as the subject line to: tmenzo at msn dot com |
| | #3 |
| Junior Member Join Date: Mar 2008
My BA-115 blows the power supply fuse on power up. Nothing looks fried. Should I pull the fets (Q2, Q5) and ohm 'em out to see if they are blown? do something else? Test the drivers too (Q1, Q4)? I have schematics and know my way around tube amps. thanks for any help or recommendations. |
| | #4 |
| Old Timer Join Date: Jun 2007
I'd suggest checking the output first and then the power supply diodes/bridge.
| | #5 |
Thanks Bill. I'l check them tonight.
| | #6 |
No need to pull them, just see if they check shorted where they sit. If they do, THEN pull them. There is nothing in the circuit that can make a shorted part appear not to be.
| | #7 |
The outputs are blown. Dead short. Where do you buy these things? Mouser lists them as OBS, can a sub a IRFP140A for a IRFP140R? IRFP9140PBF for the original IRFP9140R? Here is a link to the IRFP9140: (http://www.mouser.com/Search/Product...%252bQYw%3d%3d? Thanks again for your help. |
| | #8 |
Pb is the symbol for lead in the periodic table of elements. When you see PBF after a patr, it means it is "PB Free" - in other words no lead in it, lead free. This satisfies the current ROHS rules for Europe. The PBF version of the parts drops right in for the older version. Yes, you can make those subs. |
| | #9 |
Thanks again Enzo. the RoHS compliance makes sense. I know a lot about this. |
| | #10 |
Just a quick follow up. Replacing the outputs and drivers fixed the amp. Thanks to all for the help. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Bass Damping via NFB ? | petemoore | 5 E 3 | 1 | 01-23-2007 02:04 PM |
| Ampeg V4 bass pot problem...? | acorkos | Vintage Amps | 4 | 01-09-2007 08:43 AM |
| SWR LA 15 Bass amp problem | Mardvard | Maintenance, Troubleshooting & Repair | 3 | 11-17-2006 05:02 PM |
| Holmes B-75 bass amp | JC@ | Other Amps | 3 | 06-07-2006 02:08 AM |
