I hope you just stated that wrong. The ONLY thing a power amp output should even connect to is a SPEAKER. The POWER AMP IN should ONLY see line level signal, NOT the output of some other power amp.
If nothing lights up, then your low voltage power supplies are probably missing.
Get the schematics from Peavey qand start checking out the powr supply.
LinkBack URL
About LinkBacks
