Old 03-07-2007, 02:21 AM   #1
odd Orange problem.
So I installed a PPIMV on an Orange 120.
the type with a dual 1M and the 2 extra caps.
Now for some reason the V2A is clipping, becoming a pulse generator.
The amp uses V2B pins 1&3 to drive the output tubes.
Now here's the odd part.....if I inject a signal into the FX return jack, everything is fine, V2A amplifies great, and the MV works as it should
I tried different preamp tubes.
I quadruple checked my wiring, but I'm sure I'm missing something stupid.
drewl is offline   Reply With Quote
Old 03-07-2007, 03:06 AM   #2
Okay so apparently you need input grid resistance for a stage to amplify.
The grid resistor was on the "send" jack that I removed to install a standby switch.
Orange AD200B Mk II Bass Amp TDS Maintenance, Troubleshooting & Repair 16 02-22-2010 10:25 PM
Orange or Matamp?? mac1amps Repair and Restoration 3 11-12-2007 09:02 PM
Orange Amps Mnordbye Theory & Design 0 09-28-2006 02:31 AM
Want to build an Orange head elvisjer Theory & Design 3 08-21-2006 11:03 AM
