Results 1 to 24 of 24
Thread: Peavey F-800G Super Festival Series Amp goes from bad to worse...
    Member SYSDOA's Avatar
    Mar 2010
    45
    Hi,
    I have a F-800G for a customer that has been restoring it but it never had the fuzz and phase section working. I went through the preamp and found several of the SPS953 transistors bad as well as several polar caps. They were replaced and I still didn't get a response. Looking over the power section two of the pre drivers were reading bad and I switched them out as well. No I have no sound! Little bit of a pickle. The amp isn't worth the stress, but it means something to the customer and I'd like to make good on it for him. Any ideas? The amp powers up with lights n all. There's no sound now so I'm afraid I've shot a couple of the outputs on the back of the amp. I'm worried about testing while it's on because the damn thing is huge and the humongous filter caps are in a terrible position.
    Schematic below. Thanks in advance.
    Attached Files Attached Files
    Dec 2008
    Wernersville, PA
    11,910
    Quote Originally Posted by SYSDOA View Post
    Exactly which transistors did you replace?
    Did the replacement part numbers match with what was installed?
    What test equipment do you have available.
    DMM, scope, signal generator?
    Mar 2010
    45
    Thanks for the fast response JPB!
    I have all three, but still sitting on the longer end of the learning curve I'm affraid. I switched out the ep430's which have a comparable NTE match for nte291. Writing out loud now however, this is the moment that something changed. At least I've learned not to immidiately toss replaced parts, I'll reinstall, but what do you think might be keeping the fuzz and phase from working? I'm trying to look at the schematic as an explanation, but home grown hasn't really ever lead me to logic... minus the hard way...
    Dec 2008
    Wernersville, PA
    11,910
    I cannot find any info on a EP430 transistor.
    The NTE291 is TO-220 package NPN, Base Collector Emitter (from the left) pin configuration.
    I am not an NTE fan, at all.
    If the pinout is the same, the NTE's should not have brought down the amp.
    Check the actual board & see if this is true. Base Collector Emitter leads must go to the components that the schematic shows.
    Also look for inferior soldering that may have occurred.
    Get the amp working, then the other stuff.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    28,874
    We have posted this before, but someone made it a sticky.
    Go to the Schematics Request section, and up in the stickies is a copy of the Peavey semiconductor cross reference guide. VERY useful if you service PV gear.
    The EP430 is just a TIP 31C, and the EP431 is a TIP32C.
    Or just about any similarly spec'd transistors. Not very critical at all.
    I have never seen a TO220 transistor with a pinout other than the standard BCE.
    And stay away from that NTE junk.
    And I totally agree: get the thing working, THEN worry about details like the phaser.
    The power amp runs on +/-50VDC, the preamp runs of +24v. The 24v comes from the +50v. Any chance you killed the 24v to the preamp?
    When power is turned on, is there a speaker thump?
    And better get used to working on it while it is on, you can't accomplish anything with it off.
    Mar 2010
    45
    Thanks for the quick responses. Yes I don't like NTE but in a pinch... forgive me. This place is a mad house these days and getting amps back out if I have parts of any equivalence stocked within 48 hours is optimal right now. I replaced the ep430s and have revived the amp as hoped. So on to the original issue of no fuzz or phase. Thanks for the note, Enzo. The cross reference is great! I have a stockpile of the TO22 TIP X transistors that I recovered from a estate sale that suddenly have purpose. There is a slight thump when turning the amp on right now. There's lots of maintenance concerns with the amp as far as caps, most of them are leaking from what I can tell, but I apparently am still having issues with properly diagnosing transistors , doesn't seem to be stopping any other stage of the amp. I notice no reverb as well. I don't have a problem with the 400 series stuff and working on it while it's on, this thing is just so big, no counter space. Checking voltages compared to schematic now, but any advice as to where to focus on to help get this thing outta here would be much obliged!
  7. #7
    Dec 2008
    Wernersville, PA
    11,910
    May I kindly advise working on one thing at a time.
    The amplifier is operating, correct?
    How about we start with the reverb.
    The first thing I would check is the resistance of the coils on the reverb tank itself.
    The input coil is typically a lower resistance than the output coil.
    The in & out should be indicated right on the reverb tank.
    After that (or during) check the reverb cables themselves.
  8. #8
    28,874
    Amen, one thing at a time. Focus.
    I agree, check the revern pan itself for opens.
    And check the amp. There are the two cables to the pan, one is drive and the other return. Turn the amp on with reverb up partway. Now with the reverb cables unplugged from the pan, touch the tip of each plug with a finger. Does one HUM? That would be the return, and should plug into the OUTPUT jack on the pan. If neither hums, there is trouble in the recovery circuit.
    The remaining cable is the drive end. Check for signal at the tip. Well assuming there is a test signal at the amp input jack.
  9. #9
    Mar 2010
    45
    Yes! I can appreciate the guidance. I need it. I've been able to recover the reverb section. I think I had just plugged it in backwards. I didn't know that little trick about identifying the return lead. Very cool. Won't to have to worry about making that mistake again.
  10. #10
    Dec 2008
    Wernersville, PA
    11,910
    So what's next.
    The Phaser or the Fuzz.
    I take it the Tremelo is operating properly.
    (why did I ask?)
  11. #11
    Mar 2010
    45
    Funny you mention that... that doesn't work either... doh! I thought 'rate' was something to do with the fuzZ but i see it now on the schematic!
  12. #12
    28,874
    We usually think of the phaser as a swirling chorus or flange type effect. I may be wrong, but I don't think there is any time related effect in this phaser. In this amp, phasor is just more like a variable filter. So if the fuzz is not working, then the associated phasor probably won;t either.
    I am a big believer in fixing problems before general overhauls, but this amp is 30 years old. See those little 2uf/35v e-caps strewn around? Get rid of them, replace them. When they dry out and get leaky, they no linger contribute to keeping DC levels where they belong, nor do they pass signal like they should. All the various signal path electrolytics.
    Fix the fuzz. First, does the footswitch have to be on to even get fuzz? Kinda looks like it, I may be wrong.
    The first group of three xstrs is the input stage, then another xstr and the fifth xstr is the fuzz stage. Looks like signal is through all those all the time, so is there signal atop the Fuzz pot? and out the wiper?
    Now look at the two JFETs by the Fuzz FS pin. One is P type and one is N type, with a common control signal. So when one is on the other is off. Work the FS on and off. Does the gate voltage toggle off and on at each? Measure resistance across source-drain at each JFET while the circuit is running. Do they toggle between low and high resistance as the gates toggle? A bad JFET could easily kill the fuzz.
    Look at those JFETs, one selects the clean input stage signal, the other selects the fuzz output. The line betwen them is the output to the rest of the amp. See the phasor? It is just a parallel gain stage to the other fuzz stage and it gets mixed it prior to the JFET. SO the phasor ONLY works when the fuzz is on since it is just a section of the fuzzz circuit.
  13. #13
    Dec 2008
    Wernersville, PA
    11,910
    Nice analysis Enzo.
    Here is the Phasor part of the instruction manual.
  14. #14
    28,874
    Oh, cool, I didn't know they had a theory page written up.
  15. #15
    Senior Member Euthymia's Avatar
    Alameda, CA, USA
    267
    SYSDOA, a shop as close as you are to Anchor Electronics in Santa Clara should be able to avoid the NTE. ;-)
  16. #16
    Dec 2008
    Wernersville, PA
    11,910
    Peavey F800 Manual
    Here is the complete manual.
  17. #17
    Mar 2010
    45
    Haha! @Erik - I use Halted and Jameco for the most part, but their not always convenient so I make pit stops over at Frys from time to time, but I'll definitely check out Anchor! I've replaced all of the e-caps on the preamp and voltages seem to be lining up with the schematic again. I can't find anything suggesting whether the foot switch is needed or not, but I'm building one per customer's request. He didn't have one either. Voltage on the FETS obviously isn't switching at the moment so I'm hoping the foot switch is the answer.
  18. #18
    28,874
    You don;t need to build a FS for this test, ground a clip wire and touch it to the footswitch points on the schematic.
  19. #19
    Mar 2010
    45
    Aww! good to know. I went ahead and built the box anyway. CST is stoked! I switched out the 2.2' e-caps and 100uf's as well. I had a couple sitting out anyway. Sadly now the amp has low distorted output. I crank the volume all the way up just to barely get signal. I used an audio probe and found spots on the board where the signal cleans up again but is still somewhat low compared to the umph it had before. That could just be the audio probe too tho, pretty grass roots lookin'. Thanks for all the help on this one. It's funny, I've worked on some nicer stuff over the last couple of weeks that would be seemingly twice as complicated and quickly was able to service them, but this guy is still hangin' around. Did I install a new cap backwards, possibly? Checking the test voltages noted on the schematic again...
  20. #20
    Mar 2010
    45
    I was able to get the amp back again. Tested good on fuzz, overdrive and reverb, still no phase and tremolo... any suggestions?
  21. #21
    Jan 2009
    Cleveland, TN
    65
    I actually have one of these here right now and was wondering if a footswitch is needed for the fuzz to be operational.
  22. #22
    Mar 2010
    45
    It looks that way. I was able to test the different fx grounding the leads that go to the footswitch as mentioned above by Enzo. I made a footswitch and now the fx work but only when the footswitch is connected..
  23. #23
    Jan 2009
    Cleveland, TN
    65
    cool, thanks for the info!
  24. #24
    Aug 2011
    1
    Hey, Fix mine! Please!
    jim diamond
    jmosrite@hotmail.com
    313-961-6740
  1. Peavey Triumph 120 - Bad relay causing bad sound?
    By booj in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-23-2010, 06:32 AM
  2. 5150 ii...super bad feedback!
    By guitarn00b in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-19-2010, 06:24 PM
  3. Replies: 7
    Last Post: 05-19-2009, 03:11 AM
  4. JC-120 from bad to worse
    By Craig Gildner in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-05-2009, 06:04 PM
  5. Super Reverb speakers: series // or // series?
    By Victor Denance in forum Build Your Amp
    Last Post: 11-15-2008, 11:21 PM
