When you get the new fuse, try it without the power tubes installed.
If the fuse holds, try one of the output tubes in one socket.
If that holds, using the same tube, check it in the other (3) output tube sockets.
If that holds, try each output tube one at a time.
LinkBack URL
About LinkBacks
