Results 1 to 2 of 2
Thread: SWR WorkingPro 2x10c distortion issue
    Dec 2010
    1
    Hello friends,
    I have an SWR workingpro 2x10c solid state combo amp. When running a signal into the standard input with all pots set at 12 o clock, the signal sounds very distorted. I have tried a basic troubleshoot, and it seems like the amp is not getting enough signal. With the gain maxed out the clip LED does not light even under heavy play. I tried running an effect processor through the effect loop with the same result. I have pulled the unit out and visually inspected the boards for obvious failures to no avail.
    I am thinking it may be a preamp issue, but am really just taking a shot in the dark.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,042
    Use the FX loop.
    PLug into the amp like normal, and connect the FX send to some other amp. What does that FX send sound like coming out over there? Clean or distorted? And I think you tried this - plug the guitar into the FX return, is THAT clean or distorted?
    These tests tell us if the problem is preamp or power amp.
    And connect the amp to some other speaker. We could have a bad speaker here.
  1. SWR 550X- Constant hum issue
    By marginmonster in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-16-2010, 02:23 AM
  2. SWR Bass amp fan issue
    By rosssurf in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-22-2010, 10:11 AM
  3. Marshall 8100 Valvestate Volume issue on Distortion channel
    By jmarshall in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-29-2009, 06:03 AM
  4. SWR Workingpro 2x10C footswitch
    By Jiri in forum Schematic Requests
    Last Post: 11-12-2008, 10:15 AM
  5. Ibanez SD9 sonic Distortion Issue
    By Paleo Pete in forum Guitar Effects
    Last Post: 03-02-2008, 11:12 AM
Tags for this Thread
