If you're not restricted by budget, a proper soft-start with a switched-out resistor is better. NTCs are a cost cutting measure.
One good compromise is a NTC that gets shorted by a relay once the startup sequence is complete. If there's something wrong with the amp, the NTC will blow the mains fuse, whereas a soft-start resistor would just burn out.
LinkBack URL
About LinkBacks
