| | #1 |
| Junior Member Join Date: Jul 2006 Location: Madison, Wisconsin
| 5E3 Standby and Ground Wiring
Greetings. I purchased a 5E3 kit with high-quality parts, but poor instructions. Perhaps someone could clear up a few issues that I'm not quite sure about: 1. Standby Switch - After looking at a few different options, I have decided (per my kit's instructions) to lift the red/yellow PT center tap as my standby switch. Are there any concerns with this method? 2. Board Grounds - My instructions call for running the 4 top-of-the-board grounds to a lug on a PT bolt. I've seen other builds ground these to a plate (which I don't have) behind the pots, or to a rail from the backs of the pots to the input jacks, or to a lug mounted to the right-hand end of the chassis. Is there any problem with running these grounds back to the PT lug? I already have the PT center tap and 100 ohm filament 'grounds' tied to the top right PT bolt. As a lurker, I've already benfitted greatly from the Ampage 5E3 Builders forum. I'm posting here becuase this forum seemed easier to navigate, and because I noticed that the renowned Bruce Collins had already been here. I would appreciate any assistance that you tweed gurus can offer. Cheers, Wagabone |
| | #2 |
Since I did not have a brass plate, and did not want to solder a rail across the back of my beautiful pots, I combined these elements. I made a rail out of 12 gauge solid wire and installed it between the pots and chassis. Hopefully this will provide the same grounding properties as the other methods. I will post pictures if anyone is interested. Comments? Cheers, Wagabone |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Mark Hammer - thanks for the strat wiring tip .... | Todd Hepler | Guitar Tech | 9 | 01-16-2007 11:42 AM |
| Lase Dually Wiring Code? | Stan H | Guitar Tech | 2 | 06-21-2006 11:05 PM |
| 3 way Strat switch wiring with 2 pickups? | Regis | Guitar Tech | 2 | 06-09-2006 11:43 PM |
| Standby allowing sound through... | Riscchip | Maintenance, Troubleshooting & Repair | 0 | 06-02-2006 07:39 PM |
