Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 03-16-2007, 10:26 PM   #1
5E3x2 - EL84s in place of 6V6s?
I know the EL84 and 6V6 are pretty close in many regards. Other than the proper sockets/wiring, I'm wondering if I can run EL84s in a 5E3x2? I have mine running fixed biased.
Any comments/suggestions/warnings
LarryLarry is offline   Reply With Quote
Old 03-17-2007, 01:13 AM   #2
Satamax's Avatar
Location: Southern french alps, right by the Italian border
yelowjackets!
Satamax is offline   Reply With Quote
Old 03-17-2007, 02:58 AM   #3
I do have 1 pair of the Yellowjackets specifically for 6V6s that don't cut the power (YJ20 not YJSD) but I don't think I can mix them, right?
Old 03-18-2007, 09:30 AM   #4
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
The OT impedance is about right but the plate voltage, with that power tranny and rectifier, could be a little high with four EL84s, especially if they are fixed bias.
The other thing is, a quad of EL84s can be over driven into massive clipping with the same drive signal that had the 6V6s singing and fully linear.
Use a very soft 5U4 rectifier and try to keep the B+ at the plates to under 350vdc.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
5V4 recto in place of 5Y3? slidincharlie (Carlo P) Guitar Amps 13 01-09-2008 04:12 PM
5e3x2 Hum - - - get this one! Jeff E Debugging Your Build 5 03-25-2007 09:43 AM
Weber 5E3x2 heat issues Chris G Tweed Builders 14 02-27-2007 09:31 PM
cathode biasing 6V6s - is this right? HTH Maintenance, Troubleshooting & Repair 10 01-14-2007 01:35 PM
Best place for new baffle? sparky Repair and Restoration 1 01-11-2007 11:11 PM
