Page 1 of 2 12 LastLast
Results 1 to 35 of 39
Thread: Cathode bias 6L6s, Voltage rise(50v) on one power tube when treble is turned up????
    Feb 2009
    42
    Rickenbaker Supersonic M16, 2-6L6 cathode bias, 4 -12ax,u7, . I replaced e'lytics and checked resisters, grounded power cord. Was checking voltages against a B16 schematic and noticed one 6l6 had 525v and the other 480. Rechecking i found the 525v dropped to 480v with treble down and it stays with the socket when switching tubes. Could a cap in the bass/treble controls be doing this?
    On the PI, V4, sec a plate is 130v and connected to sec b grid, grid is .007v, cathode is 5.8v, sec b plate is 270v, grid is 130v, cathode is 137v. Should the sec b cathode be higher than it's grid? The sec a cathode cap,50@50, and resister go to ground 12" across the amp by the ac input but thru a .005 cap to ground which is shown on schematic with a bright switch but I have no switch in the amp.
    The amp is running much quieter and seems good and strong. Also found an M16 schematic which seems very close but no voltage listed.
    Any and all thougths would be appreciated.
    May 2007
    pacific north west
    5,891
    It sounds to me like the amp is oscillating when power or treble is applied, but only on one tube?!? Odd. Perhaps a bad supression cap or a bad grid resistor. It also occures to me that if the bias resistor has failed short that there may be too much bias voltage on that socket. Also, if that socket screen resistor has failed that would stop current and cause the high reading as well, but it wouldn't seem that it would only happen at high volume or treble settings?!? Any other symptoms?
    "I should have been born sooner. Of course, if I had been, I might be dead now." trem
    kg
    kg is offline
    Lifetime Member kg's Avatar
    Aug 2006
    571
    the PLATE voltage on ONE output tube in a push pull pair goes up when you turn the treble up?
    when it does so, does it exceed the center tap voltage, or no?
    Feb 2009
    42
    Evidently my Fluke couldn't handle the volt overage so I got out the B&K and I'm getting different voltage now. I'm getting 480v on the OT center tap. On the left 6l6 if I turn the treble past 1/2 it will read as high as 490 to an occasional 500 on the plate. On the right 6l6 I have to turn the volume up a ways before the treble will make it react and I am getting the same voltages. There is a spot on the treble, 2/3-3/4 up, where there is a pulsing noise and higher up it will squeal sort of sometimes and if I dime the treble it sometimes drops the voltage below normal of approximately 460v.
    I had matched the resisters and caps on the driver section when i did the filter caps. I have now added screen grid resisters, 470/1 watt, and suppression resisters, 1500/ 1/2 watt. I went back and recleaned,retension sockets, grounds, inputs,,,,
    The mains on/off is in the treble control, could there be something going on there?
    I'm in the novice category regards this stuff, maybe it's time for a pro to look it over.
    Thanks for the replies. Very much appreciated.
    Supporting Member
    Staffordshire UK
    1,813
    'There is a spot on the treble, 2/3-3/4 up, where there is a pulsing noise and higher up it will squeal sort of sometimes and if I dime the treble it sometimes drops the voltage below normal of approximately 460v'
    Those are pretty strong indications that the amp is oscillating - if you move the meter lead well away from the pre-amp then the effect may be reduced.
    kg
    kg is offline
    Aug 2006
    571
    billy: one thing you can try is to short out the signal at the output tube grids.
    a way to do this is to take a large value non-polar cap, say 1uF, and short the output tube grids together. this will keep the DC levels the same (preserving bias) and remove any AC signal. then try the test again, and observe the results.
    if it does NOT behave the same way, then move that cap back one stage--ie, the input to the phase inverter/splitter. then retest. to short a single ended stage's signal, just put the other side of the cap on that stage's cathode.
    this way you can determine where the instability is starting.
  7. #7
    Capacitater Steve Conner's Avatar
    Glasgow, Scotland
    6,784
    Quote Originally Posted by billyboy View Post
    Does it also show these symptoms WITHOUT the meter connected to a 6L6 plate?
    It's quite likely that the meter lead is causing the instability, especially if you have it draped over the preamp section, or near your guitar, etc. If the amp works fine when the meter isn't connected, then there's no problem.
  8. #8
    kg
    kg is offline
    Aug 2006
    571
    good point. meter lead = antenna!
  9. #9
    May 2007
    pacific north west
    5,891
    Just a note from something I remember reading... There was a post some time back where a guy had his power tubes VERY close together. Something about that caused interaction that resulted in Vp rise above the rect output at certain amp settings. I'm sorry I can't remember what the technical discussion eventually speculated for the cause of the problem but spacing the tubes further apart did fix the problem.
  10. #10
    Feb 2009
    42
    Quote Originally Posted by kg View Post
    KG... I tried your suggestion and it starts on the 3rd preamp tube just after the volume controls and before the bass/treble controls. Unfortunately it still leaves me scratching my head as to What/ why. Thanks for the tip.
    Chuck, The tubes are about 1/2 inch apart which is way closer than most. Maybe thats part of it.
    Steve,, there is definitely something going on with the test leads and where i place my arm/ hand. The 6L6 closest to preamp has the voltage problem.
    With the volumes up a bit and bass as well, the treble still adds noise and distortion when you turn it up past the 3/4 point.
    Thanks for the help.
  11. #11
    Feb 2009
    42
    Rickenbacker M16 schematic
    Can anyone see something in this schematic that might contribute to oscilations/ distortion at higher treble settings?
  12. #12
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,040
    Oscillation is just another name for feedback. It means somethhing in the circuit is picked up and fed into an earlier stage, and reamplified. The schematic shows us nothing about the layout, tells us nothig if what is close to what. If your volt meter probe is on the plate of a tubes, the schematic won;t tell us where the rest of the wire lead sits.
    Got a scope? The shielded scope leads might be better than unshielded meter leads.
  13. #13
    Jan 2011
    11
    I'm wondering if there is DC at V3A grid drive. It is this stage where compensation is boosted or attenuated. The gate drive has no load at all so any leakage in any of the small value tone capacitors will pull the grid positive and potentially out of operating range. With nearly only capacitive coupling at this grid, near field effects can be expected. I would suspect and change out the 100pf cap. that is hanging on the treble wiper. For grins I might also try the addition of something like 100K (200K+?) from V3A grid to ground for a little stabilization helping to keep the grid centered at 0V. A grounded shield can on a tube suspected of crosstalk should be very revealing if in fact there is crosstalk due to them being too closely placed together.
  14. #14
    Senior Member km6xz's Avatar
    Dec 2010
    St Petersburg Russia
    863
    Pet peeve about internet forums:
    The point that was most telling was that the amp was "quieter and seems good and strong" which ruled out an oscillation in normal usage. Almost any oscillation will have audio range artifacts from beat notes or sound tone changes. This seems like a case of not knowing what a measurement really represents, and the interaction with the observing process. Growing up dealing with RF instead of audio I learned early that observation influences are a significant area of concern.
    What concerns me is the degree in which experienced guitar amp tech jump to conclusions that are not consistent with the symptoms and observations, and the suggestion of replacing parts without evidence of the parts are bad. How can anyone guarantee their work if a 1:1 causal relationship is not found between parts changed and the cause of the problem?
    When an amp that has been working by the thousands for decades has an unidentified problem it is a low odds probability that the problem is a design or layout problem.
    I see a lot of questionable advice given on all the forums that are causing a lot of otherwise good units to be compromised by careless tinkering when the real problem has not been addressed, or in the case of DIY tinkers, over addressed.
    Overall, I suggest that if there is not enough information, usually there isn't, to ask for more specific details before making a repair procedure recommendation. If the user can't make the measurement, in fairness to him and the gear, it is best to refer him to a competent tech who would save him a lot of money and time.
    I am sure we would all be less than happy if we took our car into a shop and had the mechanic move the engine mounts over 3 inches because there is a knocking sound, or replacing the expensive engine management computer as the first step in solving a windshield problem. Although the prices are lower, the same sort of shotgunning is happening by techs on forums. In most forums, the very first advice is echoed over and over, "change all the tubes", no matter what the symptoms are. $100 later he DIY'er still has a bad amp but now also has a number of unknowns added to the problem.
    The frequent directions to restore an amp before repairing it just add too many variables and assumes the user will install the new parts as well and skillfully as the assembly line worker who made it. Fix the amp first. Then when it is no longer exhibiting the symptoms, then they can decide on their own whether they want to restore it. Two different operations and goals. Anyone can....and often does.....repeat the constant mantra "replace all the tubes and all the capacitors" that poster after poster repeats while ignoring the symptoms. What kind of tech would do that? That is right, a non-tech whose only workbench is his keyboard and should not be listened to. I do not know Enzo, but he seems to be one of the few techs on forums who does listen to the symptoms and give advice that is consistent with those observations.
  15. #15
    Glasgow, Scotland
    6,784
    Quote Originally Posted by km6xz View Post
    Yes, which is why I (and at least two other people in this thread) came to the conclusion that the oscillation was CAUSED by having meter leads clipped to things inside the amp. The original poster didn't seem to understand this concept, or really be cooperating with the troubleshooting process, so I gave up. There will be another half dozen newbies along tomorrow.
    Maybe in some chicken shack like The Gear Page but you won't find any of those here. We have two kinds of members: Experienced techs and engineers who know what they're doing, and kids with broken amps who sign up looking for a quick fix, even though they know nothing about electronics. (Some of the latter are probably techs in small music shops. )
    The former kind already know everything you said above, having learnt it through experience. The latter don't have the reading skills to wade through your posts, so will ignore them.
    Therefore, I think I proved that the Internet doesn't exist, or something.
  16. #16
    18,040
    Oh, you are still doing internet? I signed up for internet, but I finished it.
  17. #17
    Dec 2010
    863
    Hi Steve
    Yes, certainly there are people who know what they are doing but it seems that a lot of the posts are by an intermediate group...those who know just enough internet buzz words and axioms to post things that are counter productive. This forum is better than most but overall there is too much conclusion jumping that serves the person asking for assistance poorly.
    I've posted a number of times (after several posts appear telling a person to change many of the parts, or blaming bad sound on not having a $350 transformer) about fixing the problem before attempting wholesale parts replacement and been told to butt out because internet wisdom says that all problems are not spending enough on transformers or not replacing all tube or not modifying the amp.
    Often the best advice is to have a pro look at it because some measurements need to be done that the musician does not have access to. From what I have seen, very few home repairs are cheaper then a better and more complete repair in a good shop. A symptom might go away or lessen but what caused the problem that damaged the part that resulted in the symptom? One of the reasons SMD units are more reliable is that fewer people screw with them.
  18. #18
    Glasgow, Scotland
    6,784
    Oh, yeah, I forgot that classic piece of Internet wisdom. If something is wrong with a tube amp, it's always the output transformer. I blame the free troubleshooting booklets handed out by Mercury Magnetics.
    I agree with your analysis, but you'll probably never change things. (You're welcome to try.) The people who're any good at troubleshooting are too busy doing it for a living to argue every little point that comes up on a forum.
    And the trouble with these new Iphones is, they have Internet on them. That means if you drop one, you can break the Internet.
  19. #19
    Jan 2011
    11
    Perhaps, So only put factory tires on your car. Never improve the exhaust or intake system since thousands work just fine. Only allow union workers with approved licenses do your work. That your cheep overseas equipment had every bell and whistle installed that possibly could have been conceived at design time and throughout the assembly process. That the manufacturer did not cut any corners by eliminating a part here or there to save money or assembly cost. That just because it works means that no matter what it could not be improved. And don't you dare place a non-original factory part on your 57 chevy! Your amp broke due to divine intervention since it was designed perfectly and was immaculately conceived. No, never think that anything could possibly be done better than it already is..... Geeezzzze!
  20. #20
    Jun 2006
    3,313
    "seems good & strong", or is good & strong? I know it's a judgement call but we need a decision? Are you getting 25-30W clean?
    It's very possible that connecting the meter is causing instability, as Steve suggested. As km6XZ suggested, if this instability was present without the meter, then you should hear it.
    425vdc with 6L6s and a 200ohm cathode resistor is making alarm bells ring for me, 70mA per plate? I wouldn't be surprised if you had some shorted OT primary windings (check dc resistance from each power tube plate to main B+, or pull power tubes & inject a small AC voltage (0.5VAC or 1VAC - measured with a meter) on to the OT secondary to determine the turns ratio, by measuring the resulting primary voltage from 6L6 pin 3 to other 6L6 pin 3. Also check that the OT primary AC voltage from main B+/OT centre tap to each power tube plate is identical....but as with the oscillations, you should be hearing a bad OT?
  21. #21
    Supporting Member
    Staffordshire UK
    1,813
    Whilst the maxim 'there's nothing so good that it can't be improved' will always hold true, amp mods are one of those many topics where some people just have to take things a step too far, see
    Images may be disturbing to some viewers - The Gear Page
    and
    YouTube - Bad Amp Mods... video by O. www.whatosaw.com crazy
  22. #22
    Apr 2008
    Oceanside, NY
    1,642
    What Stan (km6xz) is trying to say here (and I can attest to his knowledge and wisdom firsthand) is NOT that you SHOULDN'T mod an amp, but it needs to be 100% functional first. In addition, if an amp has worked well for 10, 20, 30, 40, or 50 years or more and suddenly develops an issue, it's not in the layout or design UNLESS someone has screwed around with those aspects. If someone HAS, then you need to put on your "Technical Toilet Paper" hat, and proceed to wipe the ass of the person or people before you who screwed it up in the first place by cleaning up old goofs, and all of us here who've been at this for awhile know exactly what I am saying.
    Once you have it all sussed-out, then you can proceed to mod and experiment, but if you just jump in and mod first, it's tough to qualify your progress. Using the car analogy: if you are attempting to boost performance of an older car, you'd want to due compression and vacuum tests to determine the condition of your piston rings and valves first. If you have valve leakage or piston blow-by, you are losing horsepower. Those need to be addressed BEFORE you can maximize performance.
    But then again, there are A LOT of hack mechanics for both electronics and cars. The "enough knowledge to be dangerous" category of technician is a huge grey area.
    John R. Frondelli
    "Mediocre is the new 'Good' "
  23. #23
    Dec 2010
    863
    Quote Originally Posted by Cosworth View Post
    Perhaps, So only put factory tires on your car. Never improve the exhaust or intake system since thousands work just fine. Only allow union workers with approved licenses do your work. ..... Geeezzzze!
    The mods that are so fashionable are assumed to be improvements, yet are they? There is no free lunch in engineering, it is a creative process of compromises. When people come asking for a mod they heard will make them play and sound like Hendrix, I ask what they want specifically, and what are they willing to give up.
    There are no mods that have only positive changes.
    The point of making a more methodical and scientific approach than advocated on the internet and apparently by you is that few mods or "upgrades" can be demonstrated as improvements, they might be, they might not be but the owner has no point of reference, now system analysis and baseline measurements. Some will counter, "I will know if it is better when I hear it" but time and time again, in double blind experiments, sounds are darned hard to evaluate and an impression one has quite often is based more on expectation, wishful thinking or having a short memory. Actually, we all have short memory of sounds, we have long memories of our impressions of sounds however. Many tests on hi-fi golden ears have shown that what they hear has little to do with reality. For example, since few of the claimed improvements in sound based on high end interconnects or line cords can be measured in any way with any known criteria in mind, tests have been set up where the listeners were asked to pick out the "improved sound". When their score cards were collected, the claims of one being like "having a veil lifted" in improved sound stage with cable "B" vs the terrible "constricted, limited breath image" of cable "A" seemed hollow when the reality was that no cables were changed just a short .5 second muting of the signal to sound like a switching over. The number of variables in guitar amps and guitars make sound testers in hi-fi audio look like paragons of well grounded engineering. I've done listening tests that suggest that it is even more disconnected from reality and more subjective when a guitarist plays and listens while evaluating. There, they have a great deal of influence on the sound and full in the feedback loop determining the sound. When removing that variable, using re-amp techniques the differences between their judgement of garbage and their supreme amp becomes very blurred and inconclusive.
    So what did it sound like before the mods? What did the mods do that might lower the performance or reliability?
    Years ago, a well known producer came to do a project in my studio. After listening to the monitors he said he wanted them EQ's to remove the dominate mid and make them brighter. The prior occupant claimed the exact opposite..."OK, we do it". They were large soft mounted systems that measured perfectly as we intended them to be and I had no desire or willingness to change them on subjective notions of a producer. I had one of the seconds change the lighting angles so they were illuminated the monitors a little more, they are normal unseen in the dark region above the canted window into the main room of the studio. The next day, the producer listened, and announced that he was happy but thought be brightened them a little too much. It was expected that a change in appearance changed his perception of sound. We were used to tricking singers into pitch and mood changes by tweaking lighting and eq in the cans. This producer, I have no doubt, could "hear" circles around anyone who claims to be a golden ear modder, yet he could not separate his subjective notions from the reality.
    You bring up the 57Chevy as an example of mods improving it. Does it, maybe in selected narrow criteria but overall it will be very hard to support that claim. I've built enough sports cars and even campaigned a TransAm 5 liter sedan(Z-28) for a few years during the heyday of that series. Some very specific improvements were gained while accepting tremendous downgrades in other areas of performance and longevity. And that was with some pretty knowledgeable engineers and testing programs.
    I am still waiting for someone to show that slapping a $350 transformer in a amp makes an objective improvement in sound. Is a MM transformer better than a $100 Hammond. In some respects, possibly...not proven, but in other criteria it is definitely a downgrade. Pick your benefit and accept the compromises. Basically, good engineering is not behind the mod craze, neither is good music. I've yet to hear of an amp that made ANY difference in the appeal of a song or the sales of a recording. Have you? So, if it doesn't influence listeners judgement, what is it all about?
    I am all for hobbyests creating new systems and designs, but that is not what the mod hobby really is involved with. There is little understanding of what they have and what they want to achieve. I don't even thing the goal is to understand anything or apply reason and planning to the modding. Instead of buying the unneeded extra set of fake NOS tubes, if they were really serious they would buy a few theory and math books, and some test instruments. Anyone who can afford several hundred in NOS on a whim just to see if it makes a difference, but not afford a scope, variac, good generator and AC voltmeter is not serious about getting any improvement, any more than the kid down the street through on headers on the 57 Chevy without measuring instruments and a strong understanding of the physics and engineering involved. It is for show, not result.
  24. #24
    Feb 2009
    42
    Quote Originally Posted by MWJB View Post
    MWJB,,, OT Centertap to plate is 211 and 197 ohms left & right 6l6. Putting .926v ac on ctr tap gives me .926 v on both plates and there are o volts plate to plate, although one of my meters said 0-.001 or .002 I think its the meter doing its thing. I have 465 v on the plates, 410 on sqreens, with 30-31 v bias and about 65 ma current draw. Is that out of wack? They seem spot on with a B15 schematic voltages in a Gerald Weber book, Kendrick amps, which seems mostly identical to the M16 schematic I found on google. I don't know how much power it has. it's louder than my 15 watter, when you get above 1/3 volume and you play it hard it distorts a bit, at full throttle with the treble and bass down at 3/4 to half it just sings if you like that overdriven brown sound.
    YO Steve Conner, I appreciate your response and I respect you because I can tell you know your poop. I responded after you and another gentleman pointed me to the meter lead trouble and I said that yes indeed the meter was affecting the readings.
    After doing a basic cap job the amp did sound good until I dimed the volume and the treble with a guitar plugged in, there was some scratchiness in pots and more high end hiss of course with the treble up and then when playing power chords and leads I started hearing ghostnotes , treble distortion. So I started looking closer at voltage and thats where it all began.Thats when i went in and really cleaned the jacks and pots by pulling them and cleaning the chassis mounts, washers, nuts,,, Then I poked around at the various componets on the board and there was lots of crackle, pop which was cured mostly from reflowing the grounds on the circuit board. Perhaps I haven't explained myself very well ie. symptoms wise. I have read that some amps are prone to parasitic oscillation. I'm getting to the point that this amp is what it is and that it's probably working as it should. I just might take it to my somewhat local tech when I get a minute or two and have him look.
    Thanks for the replies, Gentlemen
  25. #25
    Jan 2011
    11
    Studied electronics back when the only transistor to be found was in a hand held Japanese radio. Studied tube technology back in 73, Semiconductor theory for 2 years in college. Electronics for 4. Had my own engineering business for 5 years. Been running cad systems since they were invented. Schematics, Engineering Drawings, Printed circuit boards, Solid Models, Circuitry Design, Troubleshooting, Drop me a line. Just some of my recent work. Hey, but what do I know... Peace Ya'll!
    Attached Thumbnails Attached Thumbnails img_2392.jpg   100_0976.jpg   100_0697.jpg   100_0691.jpg   img_2367.jpg   img_2369.jpg   img_2391.jpg
  26. #26
    Jun 2006
    3,313
    The difference in DCR isn't immediately shouting there's a problem, there is usually an imbalance, so long as it's not much over 10%.
    With the voltage test, you are supposed to be applying the .926VAC at the secondary - the speaker wires, then measuring from plate to plate of the 6L6s & from centre tap to each plate. But from what you say, there's not obviously a problem...won't hurt to check/eliminate though.
  27. #27
    kg
    kg is offline
    Aug 2006
    571
    these are some of the effects of parasitic oscillations.
  28. #28
    Jun 2007
    2,716
    That's great, I wish that I had your education and experience level, but how does this help fix the guy's amp?
  29. #29
    Feb 2009
    42
    MWJB, Thankyou for the heads up! So I put 1.12v ac into secondary and I get 51.2 plate to plate. Ctr tap to plate is 25.7v, on both. Thats good to go isn't it? I can see why you raised an eyebrow looking at the M16 schematic voltages while my voltages reflect the M15. Maybe I have the revised version sans schematic or something,
    More to the story... I was talking with a friend who plays and has his own repair shop for some 30 odd years, He, like Enzo said he'd really have to see the layout and scope it to really see what's going on. The next day I sent him the schematic and then I tried "KG's" idea of checking the stages by shorting grid to cathode with capacitor and it pointed to V3a with the .005 cap on the cathode which isn't on the schematic and I had a feeling, a wonder. I called my friend that evening and the first thing he said was "pull it". And for you less informed " like me" he said the input jacks were not a good load for guitar pickups, that the Fender setup would be much better, but did I want to mod a vintage amp? Not very badly, I replied. He then said that it was a split load PI and it would never clean up like a" long tailed pair". He said if pulling the cap didn't help as a last resort try a very small cap between the .05 PI caps,cap to cap, and the 6l6 grids. One of the Webber books does a good job of explaining this stuff,FWIW. Anyway, today I pulled that little V3a cathode cap, the one that isn't on the schematic, and the amp sounds much better. I believe that cap was put in the day this amp was born, maybe it was Friday, or it was in the wrong parts bin, or ,,,,
    I need to play the amp some more but I think I got what I want.
    Which brings me to WTF is it with you dudes who have your flame throwers on the hip. No one said I had to have a PHD in guitar, amps, computer, or music to join. I thought it was a place to learn , discuss, help, blah,blah,,, A while back there was a thread on wether or not you should help us idiots for fear we might kill ourselves. Hell, There's too many of us now and it would clean up the gene pool, just kidding. Sheezse, Anyone with half a brain would know to fix before you mod, Is A tweak a mod?Is a tweak a repair? As others have said, who wants to clean up a mod mess . The junkyards are full of great engineering. An older fella once said to me that all these circuits are from western electric to sell tubes and there were plenty of mistakes and so/so engineering in them. As Mr. Weber said, "they didn't think we'd turn up past 3". How about those fine little monkey wards amps where the tube values add to 115 or something and they were capable of killing you? For Criss sakes uknot your shorts. This is supposed to be "Hey I got an idea, try,,, blah blah blah,,,,,
    Thanks to the fella who loaded the pics of how to really mod your amp. I'm still laughing.
    Thanks to all who chimed in and helped, I truly appreciate it, even if you dissed me. I can take it. THANKYOU!!!!!!!!!!!!
  30. #30
    Jan 2011
    11
    Sorry to have "dissed" you all. I figured I could open up some creative discussion with what I though were probably like minded souls. Obviously I was wrong and am not welcome here. My 35 years of practical experience in electronics is no comparison to the "Wad you hand in a fist and give a hard Whack". Mentality, as recently posted here and met with total acceptance. Even Rudolf got better appreciation. Take Care Folks!
  31. #31
    18,040
    Cosworth, we actually welcome new voices here. Having said that, no one expects anyone to prove what they know instantly. Likewise, sometimes it pays to read a forum for a while to see what voices seem to have something behind them.
    As to the whack-it "mentality," would it sound better if I suggested using a rubber mallet - sold in any hardware store - to apply mechanical shock to the chassis to reveal intermittant connections?
    Point is that hitting the amp with your hand is about the same as using a rubber mallet, and God gave it to you at birth, you don;t have to go buy it. it is a perfectly legitimate way to expose loose connections. And if you think about it, if the amp won;t withstand a fist-whack, then it most likely won't handle the trip to the gig in the trunk of the car either.
    And just for the record, my whack it mentality has been soldering for over 50 years now, and my shop has been authorized my most of the major brands for 25 years. So we both have resumes.
  32. #32
    May 2007
    pacific north west
    5,891
    Thanks for stopping by
  33. #33
    Glasgow, Scotland
    6,784
    I have an old book, "Radio Receiver Repair and Servicing", or suchlike, from the 1950s. It actually recommends giving the "set" a "smart slap" to help diagnose intermittent faults. It is pretty much standard practice if you suspect a loose connection: poke the wiring and circuit boards, wiggle the tubes if the equipment has any, turn pots back and forth, flip all the switches several times, and yes, give it the odd whack.
    I asked earlier whether the amp still showed the same oscillation symptoms when the meter lead was removed from the plate. Obviously you can't measure the original symptom any more, which was a rise in plate voltage. But you can see if the other observations that correlated with the rising plate voltage are still present. (Excessive B+ current draw, odd noises from speaker etc.)
    Sometimes one of those electrician's screwdrivers with the neon lamp inside will show up really bad parasitics. If you wave the end with the lamp in it near your circuit, it may light without even touching anything.
    If we're looking for resumes, I have designed about a dozen scientific instruments for various companies. We have a guy like Cosworth working for us as a contractor just now, doing PCB layout so I can concentrate on design and firmware. (He uses PADS too.)
  34. #34
    Jun 2006
    3,313
    OT is good to go. Glad you got it sorted.
  35. #35
    kg
    kg is offline
    Aug 2006
    571
    i do that with my wife from time to time.
    her reaction depends on her mood.
  1. Replies: 3
    Last Post: 06-01-2010, 11:09 AM
  2. Determining necessary bias voltage from tube data sheets
    By Michael Allen in forum Theory & Design
    Last Post: 09-28-2009, 01:10 AM
  3. how do I use a 50v bias tap for a 48vDC mic phantom power?
    By mike_mccue in forum Theory & Design
    Last Post: 06-28-2009, 02:20 PM
  4. "unstablilized" cathode bias voltage
    By EETStudent in forum Theory & Design
    Last Post: 09-01-2008, 08:57 AM
  5. 6V6 cathode-bias level & tube idle-bias...
    By In The Light in forum Theory & Design
    Last Post: 02-12-2007, 02:56 PM
