Do you know the color codes for the taps? If the green and black correspond to the 2 ohm tap and common, (as on the original), then you can heat shrink the other taps as you suggest. I wouldn't cut them just in case you want to use a different speaker combination. (Assuming your kit is 4x10s.)
LinkBack URL
About LinkBacks
