You CAN make the amp more of what you want but it's good your at terms with the fact that it's simply not a "metal" amp. Sort of like trying to make a Ford Pinto into a street rod. Sure you can make a cool fast Pinto, but you can make a much faster Mustang.
The SLO mod shouldn't take away much bottom end it just won't overdrive the bottom end into mush. That doesn't help you anyway since turning the bass up past the point where it's distorting doesn't make more bottom end, just more mush.
Rather than tell us what you want it to do, when looking for a mod suggestion it's better if you tell us what the amp isn't doing for you. Then mods might be suggested to fill in the gaps. ie: "The amp is too bright" or "I want more gain but less mush".
LinkBack URL
About LinkBacks
I realize that br00tal death metal tones are impossible to achieve here and maybe a good option for that would be dist pedal (Wampler triple wreck) on clean channel with good headroom. But I hope that I could pull "metal with lesser amount of gain" from OD channel. Something like Judas Priest, Black Sabbath, Ozzy, maybe Slayer, Metallica and also shred stuff like Malmsteen, Vai, Paul Gilbert etc. Or it's impossible? I'm really fan of Mesa Boogie Mark tone too, like Petrucci and Hetfield.
