Results 1 to 4 of 4
Thread: Will this trim pot work here?
    Nov 2008
    Norwalk CT
    241
    I would like to use a trim pot in place of the 120K resistor in the bias supply in the schematic below to make my bias adjustable. At the moment I have a 100K in the amp and it works great. The trim pot is only rated for 300vdc max. The voltage before the diode is 330vac. Thanks Bob
    "Reality is an illusion albeit a very persistant one " Albert Einstein
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    1,242
    [QUOTE=rockon1;199876]I would like to use a trim pot in place of the 120K resistor in the bias supply in the schematic below to make my bias adjustable. At the moment I have a 100K in the amp and it works great. The trim pot is only rated for 300vdc max. The voltage before the diode is 330vac. Thanks Bo[QUOTE]
    Put a resistor, say 60K ohms in series with the trim pot. That will recuce the voltage across the pot by about half.
    Nov 2008
    Norwalk CT
    241
    [QUOTE=olddawg;199878][QUOTE=rockon1;199876]I would like to use a trim pot in place of the 120K resistor in the bias supply in the schematic below to make my bias adjustable. At the moment I have a 100K in the amp and it works great. The trim pot is only rated for 300vdc max. The voltage before the diode is 330vac. Thanks Bob
    Oops ,my mistake. It will be used with a 22K "failsafe" resistor. Is that enough?
    .............................I just checked and since the pot goes to basically zero theres no reason not to use a 60k -Thanks again Bob
    Nov 2008
    Norwalk CT
    241
    Still thinking...If the 330 Vac going to the diode is being 1/2 wave rectified then going to the resistor I wish to replace then its only going to see at most 1/2 of that in Vdc or 115vdc that is?
    Cmon guys I know this is childs play for you. Bob
  1. Fender Super Champ Bias Trim Pot ?
    By stratburst in forum Mods & Tweeks
    Last Post: 01-04-2010, 01:00 AM
  2. Ampex ATR-700 trim pot
    By clintronics in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-28-2009, 10:54 PM
  3. Is This a Bias Trim Pot?
    By cudamax2343 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-23-2009, 03:09 AM
  4. Marshall JTM60 Trim Pot Location
    By Nooner in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-19-2008, 08:13 AM
  5. internal trim pot for LOUD pedal
    By viggy in forum Guitar Effects
    Last Post: 08-02-2006, 06:28 AM
