If the reverb circuit is selected there is a loud hiss that gets louder if the reverb pot' is turned up. When the reverb button is pushed again, to switch off the reverb the hiss continues for a second or two and then it dies away as if an electronic component was draining.
If the FX loop is selected while the reverb is selected the hiss is niticeably lower almost gone in fact.
The last gutar played through the amp before this occurred was a bass (with active EQ), played through the Low Impedance input. Could this have causedthe problem?
Thanks for the responses.
