Results 1 to 4 of 4
Thread: Korg AG001 host connection cable
    Jul 2007
    547
    Hi all,
    I am looking for pinout of the AG001 serial communication cable used by Korg to host computer connection.
    This cable has 8-pin Mini DIN male connector at the one side and DB-9 female connector at the other.
    I have checked few suchlike computer cables and detected to my surprise that all
    they have different schematics (Apple’s cable has non-standard RS-232 connections,
    Macintosh’s one has RS-422 connections and so on…).
    For this reason, if somebody has Korg genuine AG001 cable, it would be very appreciated
    if you could take some time to find connected pins and send pinout as a connection table
    or schematic.
    Connectors pin arrangement is attached for reference.
    Thank you in advance.
    Attached Files Attached Files
    Dec 2008
    Wernersville, PA
    11,910
    So what goes where?
    The DB-9...
    The 8 Pin Mini-DIN.....
    I was under the impression that serail data across a DB-9 connector was a standard.
    EIA-232.
    Link: The RS232 Standard
    Link: Tech Info - RS232 Cables and Wiring
    Link: RS232 serial cable pinout information
    May 2011
    Manchester UK
    68
    The following models used this serial interface:
    AG10 / C-8500 / C-4500 / Ci-8600 / Ci-9600 / Ci-800 / C550 / C-560 / C-900 / C350 / EC120 / EC320 / EC350 / i30 / is40 / i5M / i5S / iX300 / N1 / N1R / N5 / N5EX / NS5R / NX5R / 05/RW / X5 / X5D / X5DR / 05RW / Pa80 / TRITON Classic / XC1000, / XC2000 / XC3000if / FC500
    Source: Korg
    It was designed to connect with a straight pin-for-pin lead to Apple Macintosh computers with a standard 8 pin min-DIN lead as used for printers and MIDI interfaces. Korg's own lead was called AG-002B.
    For PCs, a Mini-DIN 8 to 9 Pin D lead is used called AG-001B. This is how it is wired:
    Jul 2007
    547
    Quote Originally Posted by Martin Pedder View Post
    Source: Korg
Name:	Korg AG-001B & AG-002B Serial Leads.gif
    I have already received this information a year ago.
    But I want to thank you in any case.
  1. Screened grid-wire: shield connection to Plate pin?
    By overtone in forum Theory & Design
    Last Post: 04-19-2010, 01:41 PM
  2. Replies: 4
    Last Post: 03-31-2010, 08:44 PM
  3. Pre-Amp To Power Amp Connection
    By JRK in forum Guitar Amps
    Last Post: 01-26-2010, 04:29 AM
  4. speaker connection to ground
    By Marc in forum Theory & Design
    Last Post: 11-15-2008, 03:33 AM
  5. Fender/Groove connection
    By Enzo in forum Tubes (Valves)
    Last Post: 09-11-2008, 09:39 AM
