Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Debugging Your Build
Old 03-25-2007, 09:34 AM   #1
Need Help in Phoenix?
There is no substitute for one on one help in building anything. Also there are so many rediculous schematics floating around claiming to be certain models. I've been helping local folks get their projects up and running and it seems to all come down to the wrong schematics, or following hook up diagrams instead of schematcs, and then solder connections. Bad solder connections will ruin your freaken life for years. I had one amp for 3 years that never sounded right and I had soldered the wire cover instead of the wire in the cathode follower and years of frustration ensued.
Anyway send me a message if you need help in the phoenix area on a limited basis.
I'm very interested in meeting a guru on mic pres. I'm just dabbling right now.
I also do 3d cad on all my designs and use protel for circuit boards.
Chadwick is offline   Reply With Quote
