Results 1 to 32 of 32
Thread: my homemade BPSSC
    Jul 2007
    51
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    my homemade BPSSC
    I know there's been discussion about the Suhr-Illitch patented Silent Single Coil system, though I don't know if anyone has gotten around to testing their own version.
    Well, I followed the patent and built my own to appoximately those specs. I wound an approximately 8 inch diameter coil of about 200 loops of 34 awg wire, shielded it (very necessary) and wired up a couple of 5k trim pots with a cap on one of them. It's stuck to the back of my hardtail strat, and I'd say it kills about 80 percent of the hum.... More accurately, with the trim pots properly adjusted it kills all of the low frequency hum, but still a fair bit of higher frequency noise gets through.
    More on the trim pots: The patent shows 10k ohm trim pots with parallel resistors of unmarked value. I used 5k pots and still all the action occurs near the end of the pot. I suspect they use a 1k or 2k resistor in parallel with their 10k trim pots just to make them log-tapered, so you could do the same or just use a 1 or 2k trim pot and i'm sure it would be fine.
    Upon adjustment, I found that there was a sweet spot on the trim pot where there was the highest cancellation of hum; going below this introduced more low frequency hum, and going above this introduced more high frequency hum. The trim pot with the cap has a barely noticable effect, as far as i can tell.
    I just found Joe Gwinn's comments on calculating the size/winds of a noise cancelling coil, basically area * turns = hum sensitivity, however he also mentions that core material factors in, though doesn't say by how much.
    My pickups are a 5k tele pup and 5.75k strat pickup, 42awg wire. Area is approximately 1 inch square, times about 6000 winds, so hum sensitivity not including the factor of core material, is about 6000.
    Noise sensing coil is about 6" by 10", or 60 inches squared, and about 200 turns, therefore it's hum sensitivity is about 12000, and being an air coil their is no added core factor.
    So Joe, what is the added factor of 6 alnico slugs?
    I imagine it's better having a larger than necessary noise sensing coil, since the parallel trim pots are used to bring its hum voltage down to the right level to match that of the pickups.
    So it's not perfect (not sure if it's the design or my version of it or both), I'd say the guitar is overall about 80% quieter with no noticeable change in tone whatsoever as far as i can tell, but the level of noise present still fluctuates depending on the position of the guitar; perhaps this is due to the noise sensing coil being on the back of the guitar and could be improved by having the coil on top, surrounding the pickups.... I might try this out.
    -Andy
    0 Not allowed! Not allowed!
    Jul 2007
    51
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    the noise sensing coil, by the way, measured about 125 ohms.
    Jan 2007
    Stockholm, Sweden, Europe, Terra Nostra
    607
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thanks for sharing. I have a lipstick pickups guitar build coming up (just need to learn to wind them lipsticks, have trashed a few already...) and I was thinking about using a noice canseling coil like this so its great to hear that it works pretty good for you
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,946
    Thumbs Up/Down
    Received: 2/0
    Given: 3/0
    Quote Originally Posted by madzub View Post
    Why would you need to shield it? You want it to pick up hum. The original is not shielded.
    http://coneyislandguitars.com
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,142
    Thumbs Up/Down
    Received: 88/21
    Given: 92/9
    So is the coil wired in series?
    What was the Patent # of the Shure Device in question?
    Terry
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
    Terry
    Nov 2009
    SW Oegron USA
    163
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    wouldn't he mean *electrostatically* shielded? ie, wrapped in copper tape or aluminum foil, otherwise it would be a big addititon to the electrostatic noise proportion. And the equivalizing (is that a word) of the turns X area product implies that what is being cancelled is the magnetic proportion of the noise signal. hence you can "shield" the sense coil and still have it work.
    As long as you dont put it in a mu-metal box....
  7. #7
    Supporting Member Dave Kerr's Avatar
    489
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi Terry - patent #7259318
  8. #8
    Supporting Member
    PDX
    3,215
    Thumbs Up/Down
    Received: 4/0
    Given: 2/0
    I think I've read around here that the Alnico isn't much different from an air coil. I'm also confused by the electrostatic shielding of the dummy unless the pickup is similarly shielded. I'd drop the turns*area of the dummy down to 6000 and try it unshielded.
    Would the gauge of the large-area dummy coil need to be any larger than 42 awg?
  9. #9
    Jul 2007
    51
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I'm pretty sure we're dealing with 2 different types of noise here, the electrostatic noise and the 60-cycle hum.... We want the coil to pick up the 60 cycle hum so as to cancel that of the pickup, but the other type of noise is the same stuff that your electronics cavity picks up if it's not shielded, the stuff that goes away when you touch the grounded strings. I do believe the patent mentions shielding the coil also.
    Yes it is wired in series... in parallel there would be a serious volume drop, as the resistance of the air coil is only 125 ohms.
    Using larger diameter wire for the air coil means less resistance is added to the circuit, therefore it has less effect on the tone of the pickup.... adding 125 ohms of additional resistance to a 6000 ohm pickup is not going to make much of any difference, but if the air coil were wound with 42 gauge wire it would have somewhere around 1000 ohms resistance (just throwing a rough estimate out there), so think of the difference in tone between a 6k and 7k ohm pickup, it's significant. But between 6k and 6.1k, not so much difference. The patent suggests using any wire at least 2 steps thicker than that of the pickup, so if the pickup uses 42 awg, the air coil should use 39 or thicker. In its specific example it uses 200 winds of 36 awg wire in an 8 inch diameter coil, measuring 250 ohms. I think the only reason to not use thicker wire is for size restraints.
    I might try tapping the coil halfway, around 100 wraps, and see what difference it makes, but i'm guessing it won't make much difference considering the compensation of the trim pots.
  10. #10
    Jul 2007
    51
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    more on shielding: You can wrap a single coil pickup in copper foil and ground it and it will be somewhat quieter than without, but will continue to pick up the 60-cycle hum; shielding will never block that. The electrostatic noise is not phase dependent, as far as i know, so having two coils out of phase will not cancel that type of noise.
    When i first wired up my air coil, i had copper tape on only one side of it. There was that electrostatic noise that went away when i touched the strings, making my body part of the shield. I added copper tape to the other side so as to completely wrap the coil in foil, soldered it up, and that noise was no longer there, just like when shielding the electronics cavity.
  11. #11
    Supporting Member
    Sep 2007
    3,004
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    Both types of hum occur at 60 Hz and harmonics. The hum the loop is designed to cancel is from magnetic fields. The hum that the shield is designed to keep out is from electric fields. Shielding the loop will not stop it from picking up hum from magnetic fields; that is, it will not stop it from doing its job. You cannot cancel electric fields with this set up, only magnetic, and so you might as well make sure that it does not pickup electric fields. But it is pretty low in impedance, and so it might not pick up so much in some cases.
  12. #12
    Jul 2007
    51
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I've made some more adjustments to the guitar (i have some odd wiring going on inside) and it's now even quiter than previously reported, in fact it's nearly dead quiet... of course, the noise level still fluctuates a bit as the guitar changes positions, just as it does normally, but overall the noise is nearly completely gone, and the tone is still bright and transparent as it ought to be. I might try building a new coil and placing it on the top of the guitar, so that it would be in the same plane as the pickups, and i suspect that this would cure the directional fluctuations.
    Any idea if eddy currents would be an issue in the hum-sensing coil? I don't imagine it would matter, since eddy currents, afaik, mainly affect the resonant frequency, which, in the case of this low impedance coil, would be well above the hearing range. Any other opinions?
  13. #13
    Supporting Member
    PDX
    3,215
    Thumbs Up/Down
    Received: 4/0
    Given: 2/0
    I doubt there'll be any eddy currents if the coil is far enough away from the strings and the single coil. I'm guessing that 1/8" or a 1/4", 3-6 mm will suffice.
  14. #14
    Jul 2007
    51
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I wound a new noise sensing coil, this one larger in diameter and sitting on top of the body, surrounding most of the strat body shape minus the upper horns, approximately 12 or 13 inches diameter, with about 70 or so winds (estimated; coil measured about 55 ohms). Works well, i think a bit better than the last one, probably due to it's location on top of the body which is closer to being on the same plane as the pickups.
    It cancels more hum for the bridge pickup than the neck pickup, probably because the bridge pickup is located nearly in the center of the noise sensing coil unlike the neck pickup which is out near the edge, but possibly also because it is a Tele-style pickup with the shielded steel baseplate, whereas the neck pickup is an unsheilded Strat-style pickup.
    The position of the guitar still has a significant effect on the noise, just like how you can normally position a single coil-equipped guitar in such a way so as to eliminate most of the noise. However, the low frequency hum is completely (or nearly so) cancelled, whereas there is still significant higher frequency hum in most positions. I will try shielding the coil in aluminum (it's currently shielded with copper foil) to see if that might help... ?
    One more thing to note with this design: If there are multiple pickups on the guitar with different outputs, the noise-cancelling coil is either going to need to be optimized for one and not the other pickup, or compromised to suit both pickups equally, or else you could maybe devise a more complicated bypass-resistor/capacitor network in order to optimize noise cancellation for both pickups. Much simpler just having equal output pickups.
  15. #15
    Boston, MA area
    2,608
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Or, one can provide each pickup with its own noise-cancelling coil in series, and then switch pickup+nc-coil as a unit.
  16. #16
    Mar 2011
    8
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    What about the core then?
    Air, diamagnetic, paramagnetic or ferromagnetic?
    bpssc is air, kinman and dimarzio are iron slugs (slightly ferromagnatic) I think.....
  17. #17
    Jul 2007
    51
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    what exactly are you asking?
  18. #18
    Mar 2011
    8
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    what would be the best core for a homemade bpssc?
    My tremolo cavity is tight so I'd put a smaller noise sensing coil under the springs.
    So, I'm thinking I need the iron core to increase the "negative hum inductivity"?
  19. #19
    Jul 2007
    51
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    the bpssc doesn't go IN the tremolo cavity, it goes OVER the cavity, encased inside the cover. The larger the loop, the fewer turns you need, resulting in less windings, which gives less alteration to the tone.
    I think that increasing the inductance would alter the tone quite a bit, dulling your high end unless compensated for by using brighter pickups.
  20. #20
    Mar 2011
    8
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    If its a thin shred guitar there is not much room between the cover and springs.
    Also, how come kinman and dimarzio use metal slugs (to increse inductance on a small dummy coil) and still sound bright?
    My coil would be 3,5" x 1,5"
  21. #21
    Oct 2011
    1,951
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I pickup this old post by accident. I did a little experiment, I don't think it even come close to the cancelling effect of a true humbucker. It is very position dependent. I look at the signal with the scope, the two signals ( from the pup and the air coil) vary at different position, sometime one is bigger than the one or the other. Also, I don't think the frequency response of the two are the same. The signal pup is very high inductance and the higher harmonics are not as strong where the low impedance coil seems to have more higher harmonics. they don't cancel out. Yes, you can make the low 60Hz cancel out well, but the buzzing ( high harmonics) is very position dependent.
  22. #22
    Supporting Member
    Sep 2007
    3,004
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    Quote Originally Posted by Alan0354 View Post
    The different inductance values should not matter: they just go in series and add, and so if the two coils have the same sensitivity to magnetic hum signals, they should cancel anyway. Combined with different capacitance values, it would make a difference at very high frequencies. I suspect that introducing adjustments is a slippery slope, and that one is better off getting the sensitivity right without any adjustment in a completely passive system, and just accepting the fact that it is not perfect. The coil is just too big to work really well in any case.
  23. #23
    Staten Island, NY
    10,946
    Thumbs Up/Down
    Received: 2/0
    Given: 3/0
    Quote Originally Posted by Mike Sulzer View Post
    I haven't heard one in person, but all the audio demos I have heard sound very good. It cancels most of he hum and doesn't step on the tone of the pickup.
    It would probably be a little quieter if he wasn't sitting right next to the amp.
  24. #24
    Supporting Member
    Sep 2007
    3,004
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    Quote Originally Posted by David Schwab View Post
    The amount of hum cancellation at the beginning of the video is really not all that much. This is a promotional video intended to sell a product, a product which will work better or worse in different circumstances. Do you think the video shows, best, typical, or worst performance?
  25. #25
    Staten Island, NY
    10,946
    Thumbs Up/Down
    Received: 2/0
    Given: 3/0
    Another video. It's hard to hear the hum until about 1:05 when he has the amp cranked.
    Most of the reviews I have seen at various forums are favorable, and say that with vintage output pickups you get about a 70% reduction in hum. Hotter pickups seem to work better.
  26. #26
    Nov 2007
    Kansas City, MO USA
    128
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I just made myself a coil and a PCB following the patent info. I'm wondering exactly how Suhr stuffs it into the body. Has anyone either seen a production body with the coil around the pickups or done a DIY version they're happy with? Where do you put the coil? I made mine with AWG30 so it's a little thick to attach to the back of the guitar. I have some AWG36 on the way to do my other strat and I will have enough to redo this one if it doesn't work out, but it seems tidier all around to put it under the pickguard.
  27. #27
    Oct 2011
    1,951
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    It is very position dependent. You have position that don't do a thing and one or two position that is even worst. The point is there are a lot more position that is better and you can easily find one to stand and play. But from the demo, it does change the sound, it is not exactly the same.
    I am experimenting noise cancelling and you really has to have the cancelling coil very much the same and at the very close proximity like the big humbucker to really have true noise cancelling, all the others are hit and miss and you still have to find a sweet spot. For two to three hundred dollars, they can keep it. That must be the reason it is not popular at all. Not to mention it does not work for guitar with reverse winding in the middle. The kicker is it definitely sound different with it in vs out as shown clearly in the demo. Yes, you can argue that it does improve from the Dimarzio Areas, but don't say it is the answer for the single coil. If people nitpick about CTS pots and tear drop caps, this is a huge difference in comparison.
    BTW, I did experiment with shielding of the flat cancelling coil, I tried wrapping even the whole thing and it does not make a dent of a difference. I just left the bare coil on the back plastic plate totally unshielded.
  28. #28
    Nov 2007
    Kansas City, MO USA
    128
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    The one I made did pretty well just hanging off a disembodied pickguard, but when I put it in my test guitar (mostly hollowed out with a router for things just like this) it barely made any difference. I'm in the middle of implementing something else now.
  29. #29
    Supporting Member
    Sep 2007
    3,004
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    Position dependent just means that it is not canceling very well.
    The inductance is low (.02 H in the patent), and so electrostatic shielding should not make a lot of difference, but I guess if you want to get everything theoretically right...
    That adjustment circuit in the patent seems pretty useless. What you need most is a way to adjust the sensitivity to match the range of different sensitivities of different pickups. Both of the two adjustments are frequency dependent. It sort of looks like an attempt to resonate the circuit at about 8 KHz and then adjust the Q and the high frequency attenuation. This is not what is needed, and I suspect that this is not what is in the product in any case.
  30. #30
    Member bassetrox's Avatar
    Apr 2010
    North East, UK
    25
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    DIY BPSCC tutorial
    Hi there guys, I'm putting a simple tutorial together on how to DIY one of these things as I attempt the project myself. If you're interested, or if you guys who've done it can give me any valuable input, take a look at Experiments |
    Cheers,
  31. #31
    Jul 2007
    Manchester, UK
    155
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hello,
    Does the sensitivity control in the BPSSC schematic actually work?
    I have a guitar that has a Tele bridge / Jazzmaster neck. I figure I should match to the JM pickup and attenuate some for the Tele, so wound a coil approximately 7" diameter and 600 turns of 32AWG.
    I am trying it in a test rig with a Tele bridge pickup just mounted loose. The coil is in series with a 10k resistor across it.
    The coil just seems to add noise. I have flipped the leads and it is worse one way round, but both ways are more noisy than no coil at all.
    The sensitivity control just seems to dial in noise, and it is always better with the coil shorted.
    What could be going on here do you think?
  32. #32
    Mar 2011
    161
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Quote Originally Posted by harry View Post
    Hello,
    I would start with the air coil alone (without resistor across it) and I would experiment with its physical positions around the pickup...
    I've wound several of these air coils a few years ago and all of them already worked without the trim pots mentioned in the patent.
    Now, I'm not sure that I would associate a noise cancelling air coil to a Jazzmaster pickup: during my own experiments, I've found that "big" single coils require so much turns in the air coil to make it work that it changes the tone.
    Of course, it's just my experience. YMMV; Good luck anyway.
  1. Homemade Bucker Slugs
    By Zhangliqun in forum Pickup Makers
    Last Post: 11-14-2010, 08:45 PM
  2. metal for homemade humbucker baseplate
    By rjl001 in forum Pickup Makers
    Last Post: 03-31-2010, 06:25 AM
  3. Homemade Circuit Board
    By brokennarsil in forum Theory & Design
    Last Post: 03-08-2010, 02:34 PM
  4. Homemade Chip Amp Question
    By wadehavens in forum Guitar Amps
    Last Post: 05-10-2009, 09:23 PM
  5. Homemade Microphone
    By David Eugene in forum Music Electronics
    Last Post: 06-26-2008, 04:45 PM
