Results 1 to 19 of 19
Thread: Chassis Design
    Senior Member Wilder Amplification's Avatar
    Oct 2009
    659
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Chassis Design
    Most of the amps I've worked on and built have had the OT right in the middle of the chassis perpendicular to the PT. As I'm drawing up the blueprints for the dual rail amp I'm building, I'm thinking about placing the OT clear on the opposite end of the chassis for weight/balance purposes plus I'd like to make the front of the cab see-thru so for aesthetics I don't want any transformers obstructing the view of the valves.
    The question I have is with the OT clear on the input end of the chassis if there's a risk of oscillation issues with the OT being close to the input of the circuit. If so, is there a certain way to lead dress the OT wires to prevent the chances of this?
    0 Not allowed! Not allowed!
    Jon Wilder
    Quote Originally Posted by m-fine
    I don't know about you, but I find it a LOT easier to change a capacitor than to actually learn how to play well
    Quote Originally Posted by JoeM
    I doubt if any of my favorite players even own a soldering iron.
    484
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    It has been done.
    Hiwatt and Ampeg Portaflex come to mind.
    Just keep the wires separated from the input stage.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,030
    Thumbs Up/Down
    Received: 25/0
    Given: 27/0
    Don't forget Soldano. They did it with a high gainer. May be worth checking out their design for tips/clues about how to keep it from oscillating.
    I would think that a steel (rather than aluminum) chassis would help since it provides better shielding against EMF. And run leads OUTSIDE the chassis enclosure. Never tried it because it always seemed like a cumbersome design hurdle.
    "I'm just going to perform a bit more scientific investigation, turn it up to 11 and rip of the knob." überfuzz
    "A pedal, any kind, will not make a Guitar player more dangerous than he already is." J M Fahey
    "If you build it, it will hum..." Justin Thomas
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Thumbs Up/Down
    Received: 6/0
    Given: 0/0
    I did it this way on two amps, both of which have a high gain channel.
    Magnetic induction doesn't seem to be a problem, the main issue is capacitive coupling. So all you need to do is run the primary leads outside the chassis, or put them inside a tube of copper braid salvaged from some old coax cable, or make a shield out of some copperclad PCB stock, or simply keep them far away from the first few stages. Same applies to a lesser extent with the secondary leads and speaker jack.
    Remember that any exposed windings will radiate just as bad as the primary wires. If the OT is a drop-through type, you may have to put a bell on the bottom inside the chassis.
    Jan 2008
    Montreal, Canada
    219
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Soldano SLO is a classic example, but most brand new amp (including Marshalls) are this way. Of course, when it's PCB you can do a lot of things with whatever space you have available, but the SLO was successfully replicated with turret board construction. The SLO also has the preamp tubes up front and the power tubes in the back, allows a ridiculously short connection from the input jack to the first tube
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,394
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I build my amps this way. I've both shielded the OT plate wires and left them out in the open and never had a probelm with either. I'll have to look at exactly how I did the lead dress when I didn't shield them, but I think I just ran them along the back corner of the amp. These were built with top mount OTs, 4 gain stage preamps, steel chassis and PT and OT 90 deg to each other.
    -Mike
  7. #7
    Feb 2011
    340
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    according to morgan jones in building valve amps the ot should never be in the middle anyway. that's pretty much the worst place for it.
  8. #8
    Jul 2006
    179
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I've run them outside or inside fixed flat to the chassis under the elevated tag board.
  9. #9
    Senior Member redelephant's Avatar
    Oct 2010
    195
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Like this?
    PT and choke on one side, OT on the other.
    I have this layout for the same reasons you mentioned. No need for running wiring on the outside. The output tubes should ideally be as close as possible to the OT b/c it is in the plate to OT primary wiring you have potential transmission of unwanted signal. I have the output tubes in the rear of the chassis, behind the preamp section which is placed on the front of the chassis near the input. Never had any problems even with 4-stage high gain preamps.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  10. #10
    Sep 2008
    Prince Edward County, Ontario, Canada
    346
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    What is the reason given for this?
    I would think that what is the best or worst location would vary somewhat depending on the rest of the layout.
  11. #11
    Glasgow, Scotland
    7,251
    Thumbs Up/Down
    Received: 6/0
    Given: 0/0
    I've got a copy of the book, and I don't remember reading that in it. Just the usual about how it should be kept far away from the PT, rotated through 90 degrees, etc.
  12. #12
    Oct 2009
    659
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Yep...was already planning on the perpendicular orientation of the OT relative to the PT. Sounds like many have done it a variety of different ways with no issues which is good news.
    I've also thought about twisting the primary and secondary wires (each twisted with their own only) to cancel any potential EMI into adjacent circuitry as well. In theory this should help as well (at least that's what my brain is telling me but I could be wrong).
    Jon Wilder
  13. #13
    May 2007
    pacific north west
    13,030
    Thumbs Up/Down
    Received: 25/0
    Given: 27/0
    Quote Originally Posted by Wilder Amplification View Post
    I started doing that after it fixed an oscillation I had on a modded amp. After raising the gain the proximity of the OT primary leads caused instability. I twisted the primary leads and since most OT secondaries have multiple taps I braided them tightly. It looks nice and neat too. I do it on all my builds now. Of course, if your running your leads through a copper braid or tube it hardly matters. I have one design with a run of filament lead that exits the chassis and re enters right at V1. I wouldn't be comfortable running HV leads outside the chassis in anything I was going to sell. You can never be sure what an amp owner will do. It can really leave you scratching your head wondering what was going through their mind. So, safety first.
  14. #14
    573
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    +1.
    All amps I've built so far (and they are all high gainers) have the transformers on the opposite sides. For some reason it never felt right to me to have them in the middle Marshall style.
    Sometimes oscillations are possible but just in case I usually use a 15cm shield connected to the chassis in the middle between input and output. Also a tube shield/retainer for the first tube which is close to the OT can help.
  15. #15
    Feb 2011
    340
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    My bad I interpreted it a bit wrong
    Here's what Morgan says
    "Because coupling decays with the cube of distance [1], as the distance between offending items is increased, the interference falls away rapidly. However, simply increasing the gap between two adjacent transformers from 6 to 25 mm does not materially reduce the interference, because the transformers are typically 75mm cubes, and the spacing that applies is the distance between centres, which has only changed from 81 to 100 mm, resulting in only 5.5 dB of theoretical improvement. In practice, when the transformers are this close, coupling does not obey the cube law very well because the transformers do not see each other as point sources, so a 3dB reduction, or less, is more likely."
    Which I took to mean that simply moving them further away would not be sufficient...they would also have to be turned. I suppose that it could also mean that a few mm's of distance does not matter. However, 3db seems better then nothing.
    Hey says this later though on page 24
    "We should aim to attack all parts of this equation to minimise capacitance. Reducing plate area means keeping wires short and crossing them at right angles, whilst increasing plate dis- tance means keeping parallel wires apart. In terms of chassis layout, this means that the output valves should be reasonably close to the output transformer and the driver circuitry should be reasonably close to the output valves."
    So it seems that in order of importance, turning the transformers so that they are angled in the least noisy way is primary...
    How close the preamp tubes are to the ot seems to be of secondary importance.
  16. #16
    Glasgow, Scotland
    7,251
    Thumbs Up/Down
    Received: 6/0
    Given: 0/0
    This is true, turning the transformers to the proper relative angles has the same effect as greatly increasing the distance between them.
    However, you can make any layout work if you know what you are doing.
    This amp actually has a little hum from induction between the PT and OT, even though they are at opposite ends of the chassis, because I put them in the "bad" orientation for looks. But luckily when the HT is turned on, the global NFB makes the hum disappear.
    I had no trouble from capacitive coupling, even though the input jack is next to the OT and it has 5 gain stages before the PI.
  17. #17
    Jul 2009
    Thornton, CO
    64
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    If this is a new design/build, why not orient the OT for lowest noise, rather than just putting it perpendicular to the PT?
    For those not familiar with how to do this, you just apply power to the PT with all secondaries taped off, and listen (and/or look at the signal on a scope) to the OT output with the OT primaries also taped off.
    As you rotate the OT, you'll hear a definite difference in hum in different locations. Just orient for lowest hum and mark your mounting holes.
    It may look a little funny if the lowest noise position is at a 45-degree angle to the rest of the chassis, but it works.
    For more in-depth discussions, search here or google 'headphone trick'.
  18. #18
    Jul 2008
    Sunny Tampa, Florida
    538
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Do twist wires with AC running in them. I recall a famous name bass amp where they ended up shielding some high voltage stuff, you'd never have expected. Ampeg did a bit of that in the V4s, etc with a channel in the chassis.
    Mounting trannies perpendicular is an approximation. If you like, energize the power tranny and put a scope or ACVM on the primary of the OPT and move it around. You'll find that the best (lowest signal) condition is always some slight, goofy looking angle. The second best position is always perpendicular. Always. In some fairly exotic gear you'll see trannies mounted at an angle, but it's pretty rare.
  19. #19
    May 2007
    pacific north west
    13,030
    Thumbs Up/Down
    Received: 25/0
    Given: 27/0
    If you read the rest of the thread you'll see the OP is orienting the iron on opposite ends for appearances, not to lower PT/OT coupling. But I will say that I have done the OT placed for for loest noise thing and it works very well. It's surprising really how you often can find a spot where the EMF's don't seem to couple at all... Just silence.
  1. avalon design need help
    By samuel kwok in forum Music Electronics
    Last Post: 12-14-2009, 03:16 AM
  2. Chassis? Cheap chassis?
    By Satamax in forum Guitar Amps
    Last Post: 07-20-2009, 08:29 AM
  3. Design enviornment
    By daz in forum Theory & Design
    Last Post: 06-08-2009, 03:18 PM
  4. design help
    By mbailey in forum Theory & Design
    Last Post: 01-13-2009, 06:53 AM
  5. Box Design
    By KinkyWinks in forum Guitar Effects
    Last Post: 10-30-2007, 02:56 PM
