Old 03-31-2007, 03:02 AM   #1
Fender Ultimate Chorus heads-up
Just wanted to pass this along...
Worked on a Fender Ultimate Chorus amp today. Customer said someone else had worked on it before and that now the DSP wasn't working.
Sure enough there was no +5V supply to the DSP board.
Long story shorter - diode D71, which feeds the 5V regulator was installed backwards. The goofy thing is it matched the graphic on the PC board. Apparently the factory silkscreened the board wrong.
I'm guessing the previous repair dude saw an "obviously backward" diode installed and "fixed" it.
Mark Black is offline   Reply With Quote
Old 04-03-2007, 04:00 AM   #2
Mars Amp Repair's Avatar
the most difficult problems to fix are the ones we create ourselves! The other tech will never know.
Wise old words of wisdom..."if it ain't broke...." we all know the rest! g
Mars Amp Repair is offline   Reply With Quote
JAZZ CHORUS 55 / bad sound snowtiger Maintenance, Troubleshooting & Repair 5 10-15-2008 04:27 AM
Heads up about Guitar Parts USA Norcal_GIT_r Pickup Makers 10 06-17-2008 09:06 PM
Fender m80 chorus brick8 Maintenance, Troubleshooting & Repair 17 01-23-2008 05:05 PM
Fender M-80 Chorus Dave G. Repair and Restoration 11 01-14-2008 03:33 PM
switching between 2 tube heads on one cab per111 Guitar Effects 11 07-03-2006 02:37 PM
