Results 1 to 5 of 5
Thread: potting tele pickups
    spy
    spy is offline
    Senior Member spy's Avatar
    Feb 2009
    283
    Just finished my first tele pickup set and I have a question. Do you pot them without the cover (neck pup) and the baseplate (bridge pup)? Or with?
    ToneOholic! big_teee's Avatar
    Jun 2010
    U.S.A.
    4,430
    Quote Originally Posted by spy View Post
    I pot them both with the covers on.
    Reason behind it is that you tend to have microphonics on teles, so the wax potting with the covers on helps insulate make everything rigid.
    Make sure the screws only thread into the bridge baseplate and not the forbon.
    If the forbon is threaded and the baseplate is threaded it breaks the wax seal when you thread into both, causing microphonics.
    Good Luck,
    Terry
    Keep Rockin!
    Terry
    spy
    spy is offline
    Feb 2009
    283
    Thank you Terry!
    About the neck cover, is it easy to clean it after the potting? Isn't hot enough?
    Jun 2010
    U.S.A.
    4,430
    Thank you Terry!
    I wax pot 140-150f degrees, Pre heat, by laying over the wax pot or on the soldering iron cage.
    I pot for 10 minutes each.
    When you pull the P/Us out of the wax pot, let drip, then wipe off with a soft rag, or paper towell.
    The chrome covers I used scratch real easy, so be careful handling them.
    The bridge, I would do all the string wrapping before Potting.
    It's real easy to break the start and finish wires so be careful.
    Good luck,
    Terry
    Keep Rockin!
    Terry
    spy
    spy is offline
    Feb 2009
    283
    Really thanks Terry! Let's see what I'll do! I'll let you know about the results. I'm planning to pot them tomorrow.
  1. wax potting lipstick pickups
    By guitarmike2107 in forum Pickup Makers
    Last Post: 11-17-2010, 12:48 AM
  2. Potting pickups; tape before or after?
    By Marko Ursin in forum Pickup Makers
    Last Post: 05-22-2010, 05:27 PM
  3. Replies: 4
    Last Post: 02-02-2010, 05:16 PM
  4. unusual way of potting pickups
    By kevinT in forum Pickup Makers
    Last Post: 06-04-2008, 03:04 AM
  5. Self Potting Pickups?
    By R.G. in forum Pickup Makers
    Last Post: 08-11-2007, 12:51 AM
