Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Kit Amps
Old 05-23-2006, 10:49 PM   #1
TD_Madden's Avatar
Got a Couple Mission Amps
Two Tweedy Deluxes, one Super
First tweedy built has the Paul C Mod, uses a Celestion Blue. Using a 5V4.
Other tweedy has the "super" OT, a Reverend speaker, Paul C Mod, and the Bruce's Volume/Tone Mod. Using TAD 6L6C;s two 12AX7s and a GZ34 CopperCap.
Super is stock, but I've cycled thru a number of speakers, finally settling on a combination of an Eminence CopperHead and a Weber 10F150T.
TD_Madden is offline   Reply With Quote
Old 05-25-2006, 04:16 AM   #2
Supporting Member
Steve A.'s Avatar
So how do you like the Paul C Mod in a 5E3? I like it a lot in my Princeton Reverb but I'm not sure I like it in my tweed deluxe...
--Thanks!
Steve Ahola
Steve A. is offline   Reply With Quote
Old 05-31-2006, 04:03 PM   #3
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Thumbs up
It is a subtle mod but not a waste of time.
I like the mod but find it more useful in amps with a fixed bias, where the drive signal can be allowed to swing a little further before hitting the end of the actual fixed bias voltage causing cutoff.
The mod is not so obvious in cathode biased amps, like a 5E3, where the plate voltage of the PI is lower and the bias voltage is only about 20v to 24v anyhow.
In the cathode biased appplication with lower plate voltages, the PI has very little trouble swingiing that far with little distortion but, most fixed bias 6V6s amps have bias voltages of about 8v to 15v deeper negative then cathode biased ones.
The Paul C mod allows the PI to go a little further in peak levels with less distortion in an amp that can use the extra swing.
______________
Which reminds me....
Since most of the readers here have a strong interest or have built a 5E3, they should try a fixed bias version of the 5E3 sometime for a nice tonal change, a few more clean watts and more power tube headroom.
A very simple adjustable bias supply can be made with two 1/2w resistors, a small 22k-25k trim pot, a 1N4007 diode, a 47uF-100uF 100v E-cap and a 12" piece of wire to hook it all up.
All you do is then ground the cathode(s) wire of the two 6V6 tubes and lift the grounded ends of the two 220K resistors and insert the new bias voltage there.
Adjust the bias voltage so the power tubes are running about 9-10 watts each.
With a 1K screen node dropping resistor, the amp can usually hit about 14 watts fairly clean.
With a 3Hy-5Hy choke replacing the 5K resistor, a SOVTEK 5Y3GT, GZ30 (not a GZ34) or a NOS 5V4GA... and the new bias voltage reset so the power tubes are idling at about 9-10 watts, it will get into the 18 watt range...
the American 18 watter, a new 5E3 mod kit I am working on producing.
My newest 5E3 chassis even has the PEM nuts installed in it for mounting this choke and a larger output tranny to allow 6L6 operation if desired.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 06-06-2006, 11:26 PM   #4
Oh and to add to this...
I forgot to mention... we now have available our own octal socket to 9pin adapters for running EL84s in your tweed Deluxe.
My new MA20-18 power tranny also has a pair of high voltage taps that are 265vac for EL84s if you so desire.
Bruce
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Old 06-23-2006, 07:22 PM   #5
riscado's Avatar
bruce I'm going to add the fixed bias mod to my tweed deluxe, pretty soon, I'll probably post some samples when I have the time...
by the way, why not use the weber fixed bias 5e3 circuit: https://weberspeakerscom.secure.poww.../5e3_schem.jpg
riscado is offline   Reply With Quote
Old 06-24-2006, 09:21 AM   #6
That schem is for a cathode biased amp.
An easy bias supply to build is from a brownface era Deluxe.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Old 06-24-2006, 12:17 PM   #7
riscado's Avatar
but check at the bottom of the weber scheme, there is an alternate bias scheme for fixed biasing, wouldn't that work? (this is their version of the 5e3)
Old 07-01-2006, 07:07 PM   #8
Joe6v6's Avatar
Looks very similar to the fixed bias circuit bruce described to me. I may give it a try one day. I want to make it switchiable between cathode & fixed, I just read a post about a kendrick amp that has switchiable bias.
JOE
__________________
Resistors not Transistors !
Joe6v6 is offline   Reply With Quote
Old 07-01-2006, 09:01 PM   #9
Quote:
Yes... that should work...
I didn't see it.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Old 07-01-2006, 09:41 PM   #10
Lifetime Member
Ray Ivers's Avatar
Bruce,
Do your octal/9-pin adaptors have internal components, or are they direct pin-for-pin crossovers? I'm looking for the second kind, they seem kinda hard to find.
Ray
Ray Ivers is offline   Reply With Quote
Old 07-19-2006, 02:22 PM   #11
About the Paul C mod ...
Has anyone noticed a change in bass response using the Paul C mod? The mod will lower the input impedance of the PI, so if you use the same coupling cap before the PI, it ought to cut a little more bass compared to the stock circuit.
Shea
Shea is offline   Reply With Quote
Ebay sales from Mission Amps Bruce / Mission Amps Flea Market 0 11-15-2007 02:22 AM
Spring Cleaning At Mission Amps Bruce / Mission Amps Flea Market 0 05-02-2007 04:50 PM
Bruce /Mission Amps 5E3 Q's leucein Mods & Tweeks 3 03-21-2007 07:52 AM
NEW Mission Amps 5E3 Kits are ready Bruce / Mission Amps Kit Amps 2 08-30-2006 03:13 AM
New Email name for MISSION AMPS Bruce / Mission Amps Parking Lot 1 07-01-2006 05:00 PM
