Darn! Missed out. I could have bought a Uranus, and had a rare collectible before the name change! Now, EVERYone is gonna have a Neptune!
Brad1
Kldguitar The Neptune 5HM is a Class A, double channels head amplifier.The single-ended Class A valve output stage allows the player to crank up the volume to the desired level-flat-out . Speaker emulated headphone let player practice and record without speaker cabint, so you can practice and recording in silence without annoying the wife/flat mates/neighbors and restrict your recording time to moments when all of the above are out.
·5 watts (rms) 4,8 ohms
·one 6l6(EL34) and two 12AX7's
·Single End Class A
·Standby
·Toroidal Transformer
·Two Channels Normal/Lead
·5/3w Power SC
·Out speaker jack: 4ohm, 8ohm, 2x8ohm
·Hi-Lo impedance inputs
·Controls: Gain ,Volume, Bass, Middle, Treble, Master
·Booster/Normal SW
·FX loop
·Speaker emulated headphone.Practice in silence
·XLR out with dummy load,record without connecting with speaker cabinet
·FS jack
·Heat disspated metal enclouse.
·Precise parts used for lowest noise 5W metal oxide power resistors, 600V polypropylene film/foil
·DIMENSIONS:36.4(L)x20(W)x27(H)CM (Unpacked) 60(L) x 32(W) x 34(H)(CM) (Packed)
·WEIGHT: 9kg (Unpacked),11kg(packed)
Tube Guitar amplifier,effect pedal and studio gear manufacturer kldguitar
Brad1
kldguitar how does uranus sound? I have a feeling that it's quite muddy.... at least something smells funny here!
