Results 1 to 3 of 3
Thread: ELK EL-30
    Jun 2011
    2
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    ELK EL-30
    G'day,
    I have just acquired an Elk EL30 amp and I'm seeking anyone who has some experience/knowledge of them.It has toasted 5AR4 valve and power transformer.So I'm trying to track down the correct size and Primary voltage power transformer( Australian mains voltage is 240vac ) Any info. you can give would be appreciated?? a schematic would be great??
    Thanks
    Mark
    Canberra
    Australia
    0 Not allowed! Not allowed!
    Old Timer Gtr_tech's Avatar
    Nov 2007
    Owosso, Mi
    1,616
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    These are just Fender knockoffs, so whatever model its closest to (Deluxe rev?), just use a replacement for that. Since the recto tube was wasted, its likely the filter caps are gone as well.
    Jul 2012
    1
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I have an Elk Custom 30 with the same problem, no vibrato. The tube that controls the circuit is 6AQ6 as I can best remember. While many of the characteristics are similar to a 12AX7, there are differences in plate voltages and the heater elements, as I can vaguely remember. Rather than dig into the circuitry, I'm going to find the correct tube and try it first. I'll get back to you in the future if I have positive results. Good luck in your search. Ollie
  1. elk amp 50 with matching 2x12 cab
    By siamesedream in forum Vintage Amps
    Last Post: 04-30-2014, 08:33 PM
  2. ELK Guitar Man tremolo mod
    By Tristan in forum Mods & Tweaks
    Last Post: 02-12-2011, 03:16 PM
  3. Old Elk Viking Amp Head Scratcher
    By jcollins in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-26-2010, 06:52 PM
  4. Elk Miyuki Custom 45
    By rasilly in forum Vintage Amps
    Last Post: 04-01-2010, 09:39 PM
  5. Elk Custom 45
    By Phostenix in forum Vintage Amps
    Last Post: 04-01-2010, 09:32 PM
