Old 04-10-2007, 04:23 AM   #1
Marshall MG100 FX master volume
A customer brought me this amp after he replaced the MasterVolume pot.Now the Master only works when turned to about "8" and is uncontrollable.The owner claims to have used the same value as the original pot (50k).-So with this info I tried both Audio and linear taper pots (50k) with no apparent difference.I have no schematic but I assume he has the wrong value pot.I need help.
Teleman55 is offline   Reply With Quote
Old 04-10-2007, 01:42 PM   #2
Amp Kat's Avatar
Sounds like a connection problem. Check those pads real well and make sure they haven't been damaged or not making a connection. Put your ohm meter on the leg of the pot and check continuity to where the trace takes you.
__________________
KB
Amp Kat is offline   Reply With Quote
Old 04-11-2007, 06:29 AM   #3
5k, not 50k. C taper
Marshall part number
VRCD0038 - POTENTIOMETER 1601 C5K 15MM
Old 04-14-2007, 02:03 AM   #4
Thanks Enzo, I had a 10k which seemed to work fine.I kinda figured it would be 5k or 500k,I guess the owner remembered the value had a 5 in it.I'm glad I keep some dead gear around to farm for parts.
Cross-line master volume problem Fred G. Mods & Tweeks 20 04-30-2007 09:33 PM
Ground issue in my master volume Guild: bad wiring? slidincharlie (Carlo P) Guitar Tech 8 04-21-2007 07:10 AM
Ampeg master volume footswitch walkman Vintage Amps 12 04-08-2007 01:08 AM
Marshall MG100 HDFX Troubleshooting bloodynoone Guitar Amps 3 03-14-2007 02:27 PM
Master Volume twin Reverb Krong Vintage Amps 5 10-31-2006 04:47 AM
