Results 1 to 10 of 10
Thread: Anyone Got Picts of BF Deluxe Under Hood.
    Old Timer Amp Kat's Avatar
    Jul 2006
    Baton Rouge,LA
    1,440
    Trying to run the wires like Leo did under the board but not sure how they run. This is a Weber clone kit and it seems a little different and I didn't have a shot of it. Looking for how they go through the holes to the main bd. TIA
    KB
    Dec 2008
    Wernersville, PA
    5,369
    Ther are a couple of shots on this Google Image search.
    fender blackface deluxe - Google Search
    Jul 2006
    Baton Rouge,LA
    1,440
    Thanks JazzP but didn't see any under the hood shots showing how they run but was just wondering if he ran the nodes under the main board or tied them in on the top. Might have to go hit up Kennedy and Holger and see if they have one laying around.
    KB
    Senior Hollow State Tech Bruce / Mission Amps's Avatar
    Denver, Colorado
    2,892
    Are you looking for a shot under the eyelet board... I can't remember ever seeing a photo of the board from that angle.
    However, the layout line drawings from Fender were fairly accurate... it's the wires from under the dog house and filter caps that they never seemed to have made any drawings for.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
    Jan 2008
    Doylestown, PA
    1,038
    I built a Princeton Reverb from a Weber kit recently and I pretty much threw the Fender wire routing out the window. The amp ended up dead quiet so I must have done something right. I used a 50ufx2 500 volt cap for the plate and screen supplies and 47uf radial caps at the front edge of the eyelet board attached directly to the bus bar at the back of the pots. I did follow a layout from the internet for some of the under board wiring but all the B+ supply lines were run over the top of the board.
    Here's a link:
    Anyone else find Fender builds frustrating? (Blackface Princeton Reverb
    I think you could do similar things with a Deluxe and rework the grounds just a tiny bit and end up with an amp that's easier to troubleshoot and quieter.
    jamie
    Jul 2006
    Baton Rouge,LA
    1,440
    Quote Originally Posted by Bruce / Mission Amps View Post
    Yeah thats the shot I need of under the dog house. How would you do it Bruce to make it the quietest and also what about the grounding scheme ?
    KB
  7. #7
    Denver, Colorado
    2,892
    Run an 18g ground wire for the first main filter cap negative lead and over to the screen cap's negative end. Then right to the chassis ground where you'll ground the red/yellow wire from the hi-v center tap (or anodes of a FWB) to the chassis....
    or, you could run the red/yellow wire right up to where the first main filter cap is mounted and connect it to the negative lead and over to the screen cap's negative lead... etc.
    I like to use a master ground plane.... like the brass plate Fender used... but you can use 14g-18g buss wire on the back of all the pots too.
    Make sure the pots and jacks have star washers behind them to dig into the chassis.... brass or not so they are well grounded.
    Use zinc coated star washers, not black anodized.
    Hum seems to be reduced when the other filter caps are grounded right near the source of the signal path.
    Like when you ground the cathodes of the 1st preamp stage right at the same place the input jacks are grounded.... the B+ filtered node to the plate loads of those stages respond well if those cap's ground leads are near the exact same place as the stage is on the board and chassis too.
    Kerry, in a pinch I can pull my 69 SF Deluxe Reverb or my 66 BF Pro Reverb apart and take some pictures if you really need it, but I know you're smart guy.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
  8. #8
    Supporting Member
    Apr 2007
    380
    original-dr.jpgI found this photo when I was searching for my build. First one I've seen with the dual caps.
  9. #9
    Jul 2006
    Baton Rouge,LA
    1,440
    Ha thanks Bruce and yes I will figure it out, I just wanted to run those wires right and see if they went under the board for a reason but that gives me some good options on the ground and think they will be ok if I follow the schemo & layout.
    KB
  10. #10
    Jul 2006
    Baton Rouge,LA
    1,440
    Quote Originally Posted by Bill Moore View Post
ID:	14968I found this photo when I was searching for my build. First one I've seen with the dual caps.
    Thanks Bill, that is a very good shot of layout and will come in handy.
    KB
  1. Deluxe Reverb RI Bias questions as not same as my BF Super Reverb and Problems
    By Newguy in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-29-2011, 02:46 AM
  2. DIY BF Deluxe Reverb troubleshooting
    By Meddon in forum Debugging Your Build
    Last Post: 10-17-2010, 03:54 PM
  3. modded BF Deluxe reverb
    By smokey in forum Theory & Design
    Last Post: 12-30-2007, 10:03 PM
  4. Troubleshoot BF Deluxe Reverb with original parts
    By jlatrace in forum Vintage Amps
    Last Post: 07-02-2007, 05:39 AM
  5. BF Deluxe Reverb, reverb tank
    By weeping6 in forum Build Your Amp
    Last Post: 02-25-2007, 05:27 PM
