Depends on the layout and board construction. Do you have pictures?
Maybe Bruce will weigh in- he knows these things well.
jamie
Just occured to me...am I going to have clearance issues with the jack sockets using turrets and standoffs in the 5E3 chassis I have? (Hoffman)?
Can turrets be cut down in a few areas, or should I just order a new board with eyelets?
jamie
Still waiting for parts so I haven't put anything together yet.
The board is the standard 5E3 from watts, with turrets.
Chassis is standard 5e3. Probably going to use Cliff Jacks, but haven't decided.
I'll have to mock it up I guess. Worse case maybe use nut instead of the standoff, and trim the turrets with a dremel on that side.
Or be lazy and reorder a board with eyelets...but for some reason I just don't care for eyelets. Never used them though.
The turrets aren't normally much higher than the components themselves. A big 0,1uF cap would probably be much higher than the standard turret. If the layout works and you are comfortable building an amp that way, then it'll probably build and sound great!
Jake
Cool, thanks!
Guess I"ll have to see what happens. LOL Hadn't thought of that.
I'm more comfortable with turrets. I built Metro JTM45 and JMP50 clones, but went rogue and am doing the 5E3 off the fender layout and BOM at hoffman.
Some donated parts are helping too. (free MM OT doesn't suck!)
I haven't built a tweed yet, but I like using turrets. I've seen a few 5E3 boards that are turrets.
Turrets will clear the jacks, but you must orient the jacks in a particular way. I've a build at tdpri.com. that shows the way.
Lately I'm cutting off turrets 2 thru 8 (under the input jacks only) at the knuckle to shorten them. A dremel cutting wheel does it with ease. pics at Home Page
I've built using both.
It doesn't matter either way. Don't worry about it, have fun building!
In the future I invented time travel.
If it will fit, go with the Turrets, but then again I like Marshalls!
Terry
Keep Rockin!
Terry
I built a 5E3 with turrets. Never noticed any problem. I used a mojotone chassis.
