I'm kind of confused by your request. I think you need to explan yourself a little more clearly to squeeze the best advice from us.
As near as I can tell you seem to want some sort of integrated box that puts all of your control needs in one bank of stompswitches. Is that correct?
If so, I take it you would be using one switch to provide a "straight-wire" bypass for your audio path going to the amp, but other switches that control some other things indirectly.
LinkBack URL
About LinkBacks
