They use GE335 bulbs with a screw base. The blue lens cap pulls off or pushes out and the bulb screws into a socket underneath. Be very careful when working on these, as the black plastic body will break away from the threaded mounting section making the switch nearly worthless.
I use a piece of rubber tubing to remove and replace these and any other bulbs for that matter. It just makes grabbing them easier.
LinkBack URL
About LinkBacks
