Results 1 to 2 of 2
Thread: Mojo JTM45 Schematic & Layout
    ToneOholic! big_teee's Avatar
    Jun 2010
    U.S.A.
    4,453
    Here's the Mojo So Called JTM45 Schematic and Layout.
    It's actually a version of the JTM45 but with major differences.
    It uses 32uf Can Caps instead of 16uf Turret board mounted Caps.
    It uses EL34s instead of KT66s.
    It uses a 3.4K Low Impedance Output Transformer for EL34s, instead of the 8k OT for KT66s.
    It does use a Rectifier tube for B+ Rectification instead of Diode Rectifiers common with EL34s.
    The Layout is Terribly hard to follow.
    The Input Preamp Circuit is the old JTM45, not the Split Cathode of the 1987 Circuit.
    These can be used to Trouble shoot Mojo Kit Builds.
    Good Luck,
    Terry
    Attached Files Attached Files
    Keep Rockin!
    Terry
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    On a melting ice pan in the North Atlantic
    1,385
    i want to build the 45 and i also want to do that mod you referred to
    & really i dont want to get into building amps for business
    pickups are simple
  1. First Build Blues: Mojo JTM45
    By jazisded in forum Debugging Your Build
    Last Post: 10-06-2011, 01:30 PM
  2. Mission 5F4 schematic or layout
    By Rich in forum Tweed Builders
    Last Post: 05-06-2010, 04:28 AM
  3. Chassi layout for jtm45 or jcm800
    By crowez in forum Build Your Amp
    Last Post: 10-22-2009, 09:37 PM
  4. Mojo Schematic Question
    By Chauncey in forum Tweed Builders
    Last Post: 05-17-2009, 02:15 PM
  5. PV CS1000X schematic and layout
    By clintronics in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-01-2008, 01:07 AM
