The tremolo shuts down the output tubes with pulses of negative voltage.
every time the tremolo peaks, the amp is under-biased, and distorts. That's the white noise you are hearing.
You may have better luck with the bias adjusted hotter, overall. Then the pulse would not produce so much distortion.
LinkBack URL
About LinkBacks
