Results 1 to 3 of 3
Thread: BJT transistor equivalents help needed please
    Jul 2011
    UK
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hi people
    Can anyone tell me what might be an equivalent for C3198(NPN) and A1266(PNP) transistors.
    Both TO92 1=emitter 2=collector 3=base
    Got a few things in the box in a TO92 but pinouts are different.
    Anyone?
    Cheers Mitchy
    0 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,845
    Thumbs Up/Down
    Received: 51/1
    Given: 0/0
    Those are numbers from the Japanese numbering system, or Asian numbers if you prefer. As opposed to the "American" numbers like 2N4401 or MPSA06. And then ther is the Euro system numbers like BC550.
    When you see those A or C (or B or D) numbers, there is a 2S understood at the start of the number. SO you have a 2SC3198 and a 2SA1266. That might make searching for them easier. Catalogs and data books will always use the full number. On the parts themselves they don;t waste the space to print the 2S. Some makers use a K instead of 2S, so you may see KC3198
    Small TO92 asian types have the pinout left to right facing the flat side as E-C-B. AMerican types have the leg order E-B-C. And for the life of me I can never remember the order on the Euro types, I have to look it up every time. I don't use them very often.
    You can replace one type with another of different leg order if the specs are similar, you just have to turn the transistor sideways so the legs can be positioned over the correct holes.
    My records show the 2SC3198 as a 60v 150ma NPN, and since the noise figuer is listed in the quick guide, I have to assume it is a lower noise part. The 2SA1266 is a 50v 150ma PNP, also lower in noise. Not to say a regular plain old transistor won;t have low enough noise for you, it may work just fine.
    I know I keep a drawer full of 2SC3198 for some purpose, forget what now. Mackie maybe? Behringer? SOmething I fix uses them. Doesn;t help you any, I know.
    Jun 2009
    87
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Put your device numbers into the search field on this page:
    All Transistors Datasheet. Parameters and Characteristics. Transistor Database.
    It will return a page listing your device number as a link. Click it.
    It will then return a page of characteristics of the device. Near the bottom of the page is a link to "Equivalent transistors for xxxx". Take it.
    You will then get a list of many devices whose characteristics exceed those of the device. You will need to look up datasheets for them to see if they are close to what you need, but it's a good start.
  1. Peavey cs1000x transistor equivalents
    By retgaz in forum Music Electronics
    Last Post: 12-18-2016, 06:39 PM
  2. Hartke 3500 BJT
    By Jazz P Bass in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-06-2009, 04:05 PM
  3. Switching a BJT for a JFET
    By bluefoxicy in forum Theory & Design
    Last Post: 06-04-2008, 12:54 AM
  4. MXR Phase 100 - a BJT as a variable R?
    By cjlectronics in forum Guitar Effects
    Last Post: 05-16-2008, 04:44 AM
  5. mustard cap equivalents?
    By hellwood in forum Repair and Restoration
    Last Post: 05-20-2007, 01:28 AM
