Old 04-18-2007, 05:38 PM   #1
Filter cap voltage
When opening up an amp, can it just be left unplugged for a few days to let the filter capacitors drain this way, or would it take longer than that?
grandmasterflash213 is offline   Reply With Quote
Old 04-18-2007, 06:20 PM   #2
It takes longer than that...much longer! An amp that hasn't been played for months can burn a hole in your finger if you inadvertantly (well you wouldn't do it on purpose) touch something that's still holding charge.
Play safe and discharge the caps with a 2 or 3W 10K resistor (crocodile clips at each end & shrinkwrapped for insulation) from + to ground, or ground a preamp plate. Doug Hoffman suggests switching the power off (standby still in play mode) and continuing to play until sound dies.
Amps that use 2x filter caps, bypassed with smoothing resistors, in a totem pole for the first B+ node (big SF/BF Fenders, NOT brown/blonde pre '64 amps) drain themselves if you power down, unplug and put the standby into play position.
MWJB is offline   Reply With Quote
Old 04-18-2007, 08:03 PM   #3
Amp Kat's Avatar
There are several nodes in an amp so just because the B+ main supply is drained doesn't mean a preamp or other nodes are drained depending on it's resistance to ground. The larger the resistance the longer it takes to discharge which is why when the standby switch is on that is basically an open circuit or infinite resistance therefore taking it along time to discharge. You can pop a tube out and check from pin 3 to ground and find out how much DC is present on the B+ supply.
__________________
KB
Amp Kat is offline   Reply With Quote
RFI filter for guitar inputs Mars Amp Repair Maintenance, Troubleshooting & Repair 6 04-13-2007 01:54 AM
Reforming Filter Caps bob p Maintenance, Troubleshooting & Repair 7 02-25-2007 04:50 AM
Filter cap limit? MikeT Theory & Design 4 12-27-2006 08:41 PM
Parallel vs. series vs. one filter cap Chris333 Theory & Design 4 08-29-2006 08:03 PM
Filter cap bleed resistor with 5AR4? Normster Theory & Design 3 07-04-2006 02:19 AM
