Results 1 to 16 of 16
Thread: Schematic for Peavey Renown Solo 115BW
    Oct 2011
    6
    I'm looking for a schematic for the Peavey Renown solo 115 BW model - anyone got one?
    Thanks,
    Bill
    Senior Member pecorporation's Avatar
    Jan 2010
    261
    Should be one of these two...
    RENOWN.pdfrenown_400.pdf
    Attached Files Attached Files
    Jan 2010
    261
    Oct 2011
    6
    Thanks!
    - Bill
    Oct 2011
    6
    I got the board out of the Peavey Renown Solo amp, and started looking. It is slightly different from any of the ones posted so far - close in schematic and parts layout, but still slightly different. The board number is 99002146, and the schematics uploaded so far show board numbers in the 98xxxx range, so I suspect it is newer. Are there any more out there?
    Jan 2010
    261
    What problem are you having with the Renown Solo?
    Peavey should be able to get you the correct schematics 800-821-2279.
    Steve
  7. #7
    Oct 2011
    6
    Peavey Renown problems
    It belongs to the son of a friend of mine who uses it for his guitar. His complaint sounds like instability,
    so I put it on the bench and drove it into a 4 ohm resistive load and watched it on the scope. It
    would almost make rated power (22 volts RMS into 4 ohms = 122 watts) and the waveform looked clean up to
    the onset of clipping, but I noticed that it could easily be brought into oscillation (2 to 4 KHz on the scope)
    any time the post gains were much over halfway, even with no input. I was not totally surprised by that, since I have
    fixed his other Peavey, a tube finals hybrid (forget the model) and noticed that it seemed to have way too much
    gain for its own good (my design and repair experience has mostly been with high end stereo amps, like MacIntosh,
    and the last thing they do is show instability - but maybe its a guitar amp thing? Allows deliberate overdrive, I suppose)
    Anyway, long story short, I don't see anything obviously wrong, except a 22 ohm 2 watt resistor that is semi-cooked. I'm trying
    to identify which one it is, but as I said the schematics and parts layouts are just slightly wrong, but if it is the one
    I think it is, it is involved in the output transistor bias circuits, which of course could contribute to instability. (Shows as a Vishay metal film FP).
    - Bill
  8. #8
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,402
    I have drawings in my file for Renown, Renown 400, Renown 112 (or 212), and there may be others.
    Looking at the ORIGINAL Renown, not the Renown 400, and not the Reno 400, the board number for it is 99002147, so how close does that one come to your board?
  9. #9
    Oct 2011
    6
    Mine is 99002146 - that has to be closer than the 98xxx numbers I have been seeing. The exact model number is 115BW Renown serial 2A-01161780.
    Thanks!
  10. #10
    30,402
    When you have two numbers like that, one apart, it probably is that one number is for the bare board, and the other number refers to the board stuffed and complete.
  11. #11
    Oct 2011
    6
    That's it! An exact match on the layout.
    Thanks for your help!
    - Bill
  12. #12
    May 2014
    Broken Arrow Oklahoma
    3
    Just noticed this post. I'm looking for schematics for the Peavey Renown 112. Any chance the 400 is remotely close to the 112?
    Al
  13. #13
    Sep 2012
    63
    Hi Enzo,
    I saw your post from 2011 but for some reason can't view the attachment. Maybe a stale link? I believe it is the schematic I'm looking for for my "Renown 212" S/N 4A01839730.
    Do you mind reposting? Thanks.
  14. #14
    Dec 2008
    Wernersville, PA
    12,150
    Here is the Renown 400.
    PV Renown 400.zip
    If not the correct schematic, as always, a call to Peavey is all it takes.
  15. #15
    Sep 2012
    63
    Thanks. I think the Renown 400 and Renown 212 are different. I'll contact Peavey.
  16. #16
    Mar 2017
    1
    Peavey Renown Solo 212 Schematic
    Looking for Schematic for Renown Solo Series, As Jayz states above, it is not the same as the Renown 400.
    Anyone have access to service manual that has schematic and locations on the circuit board?
    The sticker on the back says Model - 212 Renown.
    SN - 3A-01528692
    Thanks
    Grant
  1. Peavey Renown Making Buzzing Noise
    By hippybilly in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-28-2011, 03:01 PM
  2. Peavey Renown Amp, blowin' fuses
    By mfreqmaster in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-31-2010, 12:29 AM
  3. Peavey Renown Problem
    By Shakey 1047 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-14-2010, 08:33 PM
  4. Peavey Renown , howling
    By Luthin You in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-03-2009, 12:59 AM
  5. peavey renown 400 reverb problem
    By sam0812 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-02-2008, 12:38 AM
