Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 04-18-2007, 05:58 PM   #1
Fred G.'s Avatar
Tone stack question(s)
I am in the process of converting a Bandmaster to a 5F6-A clone. I am pretty much finished with the major stuff - all I have left to do is change the pot values and drop the preamp voltage a bit.
It appears, when comparing schematics of Blackface vs. Tweed/Marshall, that the tone stacks are wired slightly differently with respect to the midrange control.
Would someone be willing to explain to me why the difference, and what type of "behaviorial" differences (i.e. sonic) in the tone stack would be expected?
The reason I ask is, the amp sounds nice as is with the blackface pot values and wiring. I'm curious as to what I will achieve when I switch over the pot values and the mid-pot wiring to Tweed specs.
Also, this amp goes from 0 to LOUD VERY quickly on the volume pot. It's the original 1M audio pot that was there before. Thoughts, suggestions regarding this? Is this typical of this circuit?
So far, this has been a very fun project.
Thanks!
Fred G.
Fred G. is offline   Reply With Quote
Old 04-18-2007, 06:53 PM   #2
Try Duncan's tone stack calculator to see the difference. Fender's way affects the gain a bit more than the Marshall way (well, 'Tweed way' but you get the idea). Fender's way is a bit more 'interactive'.
It might help to consider that some amps have a 'gain boost' switch which just disconnects the mid pot from ground...thus 'lifting' the entire tone stack. Now consider that the Fender way is 'adjusting' that resistance to ground...that's why it affects the gain more than the Marshall way (with the Marshall way that resistance to ground remains 25K no matter where you set the mid pot).
Then there's the Vox way which is just all wrong.
Oh yea, that volume ON/OFF thing is common if there is a bright cap. It still happens without the bright cap but a bright cap will make it even worse. Also, the original 5F6-A used a 12AY7 input tube didn't it? Big difference.
Matt T. is offline   Reply With Quote
Old 04-19-2007, 06:10 AM   #3
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
"Then there's the Vox way which is just all wrong."
WHAT!!! No way!
VOX RULES.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 04-23-2007, 04:43 PM   #4
Fred G.'s Avatar
Thanks, Matt, for the very understandable explanation. Good info.
So...hypothetically speaking, I would assume, then, that if one were to rewire a Blackface-style tone stack midrange control into the tweed configuration (pretty simple), then there would be somewhat of a lessening of the gain thrown away in the midrange control, right? Or am I leaping into an oversimplification here?
Thanks,
Fred G.
Tone Stack Tweaks Ray Ivers Mods & Tweeks 1 04-05-2007 03:16 PM
Tone Stack Calculator Stone Theory & Design 1 03-29-2007 02:33 AM
Fender Tone stack mod chocopower Mods & Tweeks 4 03-01-2007 07:28 AM
Vox Tone Stack Weirdness Daver Theory & Design 4 02-20-2007 12:09 AM
Ampeg SVT tone stack pot tapers Yossarian Vintage Amps 2 10-07-2006 05:50 AM
