Results 1 to 4 of 4
Thread: Early Ampeg B-2R
    Jul 2008
    Seattle Washigton USA
    46
    Early Ampeg B-2R
    Hi, I am working on a Ampeg B2-R and it does not match the schematic I have. I am working on problems in the fan circuit and mine has afferent resister values and the current schem even has R54A and B and no R57? Any one have a early schematic?
    Sep 2011
    119
    Call Ampeg they will give you the correct one based on your serial number.
    jason
    Dec 2008
    Wernersville, PA
    5,369
    Ampeg had a fan circuit change.
    The original circuit came on a little too late.
    The schematic is for the newer version.
    It is a pretty simple circuit.
    The LM39 output pin turns on a transistor, which enables the fan.
    Check the transistor for a shorted condition.
    If that is o/k, then monitor the LM39 output pin.
    The output level of the ic raises a certain voltage as the ic gets hotter.
    Link: Ampeg B-2 Fan Trouble
    Attached Images Attached Images
    Jul 2008
    46
    Thanks!
    Thank you. The mod worked great. I only made 1 change from 2 270/5watt series to 2 1k/5w parallel. This fit better and it is what I had in stock.
  1. Early (1957) Supro tremolo... anyone?
    By EFK in forum Repair and Restoration
    Last Post: 11-26-2010, 06:37 PM
  2. Early 70s Ampeg V2 found in the trash
    By Ampeg Student in forum Vintage Amps
    Last Post: 10-06-2010, 12:04 AM
  3. SVT B-2r fan no working
    By pontiacpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-07-2010, 01:48 AM
  4. Primary Z early Portaflexes
    By Chris / CMW amps in forum Theory & Design
    Last Post: 05-01-2007, 09:48 PM
  5. Early 4X12 Cab
    By kramps in forum SUNN
    Last Post: 11-18-2006, 11:59 PM
