If it's 60hz it's heaters, right? I'd check the ground for the 330k resistor, the cathode bypass caps for V2b and V3a and also the filter ground for those sections. And though it would more likely result in 120hz hum I would also check the coupling cap between V2b and V3a for leakage. For starters.
1Likes
LinkBack URL
About LinkBacks
