Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 04-19-2007, 02:49 PM   #1
Filter values...specifically screen grid node
On older Marshalls there were several changes made over the years to filter cap values. One arrangement that they used in the late 60s was two 100uF caps in series for the plates but then two 32uF in series for the screens...then I think it was two 50uFs in parallel for the PI. In any case, there was more filtering on the power tube plate node and the PI node than on the screen node (which was only 16uF). Since these are often considered to be some of the best sounding Marshalls...I was wondering what effect having low-ish filtering on the screens and high-ish filtering on the PI has?
Matt T. is offline   Reply With Quote
SovTek Mig 50 pot values & taper guitarslam Repair and Restoration 9 01-03-2008 08:03 PM
Fender 5f1 Parts list – Specifically Transformers. BassmanTweed Build Your Amp 3 01-26-2007 09:46 PM
what would cause the screen grid to catch on fire? MitchK Maintenance, Troubleshooting & Repair 10 12-23-2006 11:39 AM
What Values For Tone Circuit? RANDY Theory & Design 2 10-31-2006 03:41 AM
5E7 Screen Grid Resistors? JohnLochner Guitar Amps 7 09-03-2006 03:25 PM
