Results 1 to 10 of 10
Thread: Marshall AVT 50 Head- Output problem
    Nov 2011
    9
    Hi,
    I have a Marshall AVT head with no signal at the speaker jacks.
    Headphone & Speaker emulated outputs are fine.
    Signal outputs from the power amp all the way to the jack output board & onto the jack poles...which I checked with a scope. When I earth the speaker cable through the scope probe, the speaker output is fine.
    I resoldered both sets of output jack pins but no joy. Anyone any idea what is going on here?
    Thanks,
    JT
    Near Seattle, WA, USA
    518
    Hi JT -
    According to the schematic the speaker output earth runs through some switching contacts in the headphone jack (allowing the speakers to be silenced when headphones are plugged in). Based on what you said about earthing the speaker cable with your scope probe I would guess either there is a solder problem at the headphone jack or the jack itself may have dirty or damaged contacts inside.
    Nov 2011
    9
    Hi Mark,
    Thanks for the reply. Took your advice & I cleaned/resoldered the headphone jack, but still have no signal from the speaker jack.
    Could it be a grounding issue? Do you if INTGRND is earthed to anything? There appears to be 7 different numbered references to it.
    Thanks,
    JT
    Dec 2008
    Wernersville, PA
    5,369
    That "Earth Washer" looks mighty important.
    Do you have an ohm meter.
    A few continuity checks should isolate the issue.
    Attached Thumbnails Attached Thumbnails avt50_61_02.pdf
    Oct 2007
    Buenos Aires, Argentina
    4,467
    try a *NEW* jack.
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,021
    If the jack is responsible for completing the ground path for the speakers, you can check that with an ohm meter. You have continuity or you don;t.
  7. #7
    Nov 2011
    9
    Yup you're right. headphone jack had no earth continuity. Put a dod of solder across it and away we go
    Thanks for all the help guys. I only joined this forum yesterday and already here's a result.
    Cheers,
    JT
    ps. have a mountain of gear here needing attention. I'll be back
  8. #8
    Dec 2008
    Wernersville, PA
    5,369
    Quote Originally Posted by thebunker View Post
    . I'll be back
    Is that a promise or a threat?
    Glad you got the issue sorted out.
  9. #9
    Oct 2007
    4,467
    Glad you (partially) solved it, but you still need to replace that worn jack.
    You already lost the headphone switch option, at a later date it might make intermittent contact on the speaker leg too.
    By Murphy´s law, in the middle of an important show.
  10. #10
    Nov 2011
    9
    Yeah, it will be getting replaced for sure. Can't source any PCB mounted jacks locally tho, so soonest mail order will arrive is Tuesday where I live. The solder was just a bodge job to see if she'd fly
    Jazzy P.B.....You guys would get bored if you didn't have a challenge
    Thanks again everyone!
  1. Marshall AVT 50x OD channel problem
    By electrogicu in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-22-2010, 02:08 PM
  2. Marshall AVT-50 volume drop-out
    By Jemster in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-02-2009, 09:21 PM
  3. marshall 50/50 output trany wiring?
    By ktolon in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-14-2008, 06:02 PM
  4. AVT 50 problem
    By chuckmcpherson in forum Guitar Amps
    Last Post: 12-10-2008, 01:02 AM
  5. Marshall 275 AVT Problem
    By spongebobrob in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-01-2008, 12:06 AM
